Amount of oil for U.K. diff with cooler
blythmrk
If anyone knows this as it should be more than a jdm big case because of the pipework and cooler.
I just want to know I have enough oil before I start!
Also I please refresh my memory what brand and spec of oil I should use (I think I have some motul I bought off Chris Wilson but he had a large barrel of it so just dispensed some into an old oil container!)
Thanks Dunk, it’s quite a read!
There is a way of getting the pump working without driving the car.
When the differential oil is being replenished, connecting terminals OP2 and E1 of the check connector when ignition switch ON causes the oil cooler pump to operate for 90 -/+10 seconds so that oil also flows to the oil cooler.
Thanks Dunk
I presume you can connect a direct 12v input as there’s only 2 wires so + and - it’s a motor so presume it will just run in reverse if connected the wrong way?
Thanks Dunk��
I presume you can connect a direct 12v input as there’s only 2 wires so + and - it’s a motor so presume it will just run in reverse if connected the wrong way?����
I would guess so yes
