water pump gasket or sealent
mellonman
Water pump should come with an O-Ring to seal it against the block, not a gasket. The only gasket the water pump has is for the two bolt flange that the long steel hardline connects to which returns coolant back to the pump.
I'd recommend using the proper O-Ring & gasket if possible, much neater and designed to work for many thousands of miles.
sorry I do have the gasket it was at the bottom of the box but should I use sealent with it ?
Ah I see. Thought you had a whole water pump assembly unit.
You don't need to use sealant. Just make sure both mating surfaces are super clean and flat before installing gasket.
