Timingbelt hitting tap on cover no 4 ***SOLVED***
jza800
Are there other that can confirm if i can reuse the idler pulley, if i look on the trsm on the supra, there is nothing about play, only about turning smoothness and not anything about play on the bearing. i now many will say if any doubt buy new.. but if it is possible to reuse it, i would like to, but if not, i have no choice to buy another one.
  • 2 weeks later...
I bought e new timing belt pulley from koyo, i can move the bearing side to side if i grab the wheel/bearing, it is not much, but you can definitely feel it, is that pretty normal for a bearing to have that side to side play/moving, or should there not be any movement at all??
Edited by jza800 (see edit history)
