Big Mark Posted May 14, 2020 Share Posted May 14, 2020 Noticed that my passenger side electric mirror won't go up or down when the button is pressed and there is no sound from the motor at all. All the other functions work (left right and folding) and drivers side works. Anyone had this problem before? I've tried checking the wiring from the button to mirror and it looks like the issue is within the mirror unit. How hard is it to get to the wiring/motor inside the mirror? Quote Link to comment Share on other sites More sharing options...
Lewmc93 Posted May 14, 2020 Share Posted May 14, 2020 Noticed that my passenger side electric mirror won't go up or down when the button is pressed and there is no sound from the motor at all. All the other functions work (left right and folding) and drivers side works. Anyone had this problem before? I've tried checking the wiring from the button to mirror and it looks like the issue is within the mirror unit. How hard is it to get to the wiring/motor inside the mirror? I know on my passenger mirror the left and right movement doesn't work as the 2 movement pins that attach to the mirror are broken, so i have to set it by hand. although up and down movement works. The up and down movement is controlled by a singular lower pin, so may be worth a try prying the mirror off (or adjusting it upwards enough to peak in from the bottom and having a check to see if the pins is still attached/ or not there. Far as i can see/ search due to my recent frame problem on the inside is that a whole mirror is needed to be bought , cant seem to find parts separate. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted May 14, 2020 Author Share Posted May 14, 2020 Thanks for the info. I know where to check first now. Quote Link to comment Share on other sites More sharing options...
george.t Posted July 6, 2020 Share Posted July 6, 2020 I had the same problem with my driver side mirror. It was from oxidation in the connectors pins preventing the electrical connection. I cleaned it up and it worked fine. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted August 18, 2020 Author Share Posted August 18, 2020 Finally got around to investigating the issue. Problem is in the mirror itself. Either the motor or the wiring to the motor. Not sure if motor comes apart and can be fixed, or just needs replacing. Quote Link to comment Share on other sites More sharing options...
