Stutter on boost
sidewaysdan
Morning guys and girls hope everyone is keeping well..
Ok. So before the lockdown my car developed a miss/stutter on boost. my thoughts were the plugs/leads I had a similar problem on my old supra and was old plugs. And I’ve done lots of web searches.
So I’ve changed out the plugs to the same that came out Ngk r bcr8es.
And changed the leads to B&B OML 10mm silicone performance HT leads.
But I still have the misfire .
Plugs are at stock gap should I regap ?
I have checked all pipes for boost leak all looks fine .
Anything else I should be checking. Troubleshooting
Spec
Na-t
TT gasket
Emu ecu
630 injectors
T61 turbo
60mm wastegate
Mapped to 18psi
Thanks dan
Spec
Na-t
TT gasket
Emu ecu
630 injectors
T61 turbo
60mm wastegate
Mapped to 18psi
Thanks dan
Pulled a plug out image
If you don't get any joy on here with a solution then you might want to give Chris Wilson a call to talk through your symptoms. I've found him very amenable to having a chat over all things Supra. You probably do need to catch him when he has a moment or two to talk but if he has time to answer the phone he probably has a minute to talk. I've had a couple of occasions to call him and always found him very helpful and very pleasant to chat with. The reason I think he'd be good to talk to is he would be able to point you down and through any possible sensor fault and how to test those as all the position sensors are getting very old on these cars.
Bit of a update . So I’ve gone over the leads and everything I can think of again. Took it for a quick run up the road and if I put it in 2nd it seems to be ok/better but if I put it into D. And try to come on boost hard it’s just missing all the way through the rev range..
Hi rider thanks I will give him a bell if I have no luck .
Edited by sidewaysdan (see edit history)
I’m baffled. Took it out earlier turned the boost down to low about 10psi was fine so I gradually turned back up no problems. Back up to high boost .. ran for around 20mims fine then just started to miss again :banghead:.
I do have a new arm and 4Runner coming so will give that ago see if any better. just seems so intermittent now ..
  • 3 weeks later...
