RobSheffield Posted October 8, 2005 Share Posted October 8, 2005 seems to be coming from the steering joint area a lot of Supras i have seen/heard do it, just wondered if there was a reason and/or cure? Quote Link to comment Share on other sites More sharing options...
Elliot Posted October 8, 2005 Share Posted October 8, 2005 The only time I really had this (badly) was when my rear differential was gone Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 8, 2005 Author Share Posted October 8, 2005 its more of a clicking - DEFINATELY coming from steering area i was under the car during MOT test while an able assistant went from lock to lock Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 9, 2005 Author Share Posted October 9, 2005 bump - in the hope someone knows! Quote Link to comment Share on other sites More sharing options...
magicmatty Posted October 9, 2005 Share Posted October 9, 2005 Closest thing I can relate to was a CV joint on the way out....Does it do it freely or under load?? My Audi did EXACTLY the same thing and after a bit of investigation, the CV was making the noise and was a "bit" on its way ! ! Just a thought..... Hope you sort it Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 9, 2005 Author Share Posted October 9, 2005 Closest thing I can relate to was a CV joint on the way out....Does it do it freely or under load?? My Audi did EXACTLY the same thing and after a bit of investigation, the CV was making the noise and was a "bit" on its way ! ! Just a thought..... Hope you sort it maybe its the Universal Joint on the steering shaft - cant be CV joint because its definately coming from the front of the car unless there is a CV there too? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 16, 2005 Author Share Posted October 16, 2005 i reckon this is the Subframe bolts requiring torquing up many thanks to Paul K of Max GT for his suggestion by PM! Quote Link to comment Share on other sites More sharing options...
imi Posted October 16, 2005 Share Posted October 16, 2005 Keep me posted about how it goes Rob. Front Subframe could be the cause, however not the only cause.... Quote Link to comment Share on other sites More sharing options...
