RZtwin Posted May 5, 2020 Share Posted May 5, 2020 I have a 93.5 JDM Supra RZ 6spd. When I first purchased in 2010 I ditched the Trac ECU because I did not like the way it managed wheel slip.. I recently installed my new Haltech 2500 Elite, seems to run fine after some minor remote tuning to AFR's and idle. Before I go to far and bring car to dyno/tuner after single turbo swap, do I need to reinstall the TRAC ECU ? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted May 5, 2020 Share Posted May 5, 2020 You dont need TRAC ecu. It wont work anymore when stock ecu is removed Quote Link to comment Share on other sites More sharing options...
Halfwalker Posted July 24, 2020 Share Posted July 24, 2020 The Elite 2500 will do traction control really well. You can pick up the wheel speed signals from the T9 traction ecu ecu connector - that's a better place to get them as the signals have been cleaned up from the raw ones coming from the ABS wheel speed sensors. Function Haltech pin Supra pin Function, wiring manual page # Wire color Connects to ... Rear left wheel speed Input Elite-B08 T9-A07 RLO, Rear left wheel speed #165 GR-R Grey-Red A21 ABS pin 4 Rear right wheel speed Input Elite-B10 T9-A19 RRO, Rear right wheel speed #165 Y-B Yellow-Black A21 ABS pin 6 Front right wheel speed Input Elite-B07 T9-A20 FRO, Front right wheel speed #165 LG-B LightGreen-Black A21 ABS pin 13 Quote Link to comment Share on other sites More sharing options...
phobos Posted July 26, 2020 Share Posted July 26, 2020 The Elite 2500 will do traction control really well. You can pick up the wheel speed signals from the T9 traction ecu ecu connector - that's a better place to get them as the signals have been cleaned up from the raw ones coming from the ABS wheel speed sensors. Function Haltech pin Supra pin Function, wiring manual page # Wire color Connects to ... Rear left wheel speed Input Elite-B08 T9-A07 RLO, Rear left wheel speed #165 GR-R Grey-Red A21 ABS pin 4 Rear right wheel speed Input Elite-B10 T9-A19 RRO, Rear right wheel speed #165 Y-B Yellow-Black A21 ABS pin 6 Front right wheel speed Input Elite-B07 T9-A20 FRO, Front right wheel speed #165 LG-B LightGreen-Black A21 ABS pin 13 That's exactly what I am doing on my Supra. I upgraded to 98+ ABS and will use the digital wheel speed outputs of the ABS ECU on the Elite for traction control. Just make sure to enable the internal pull-up resistors on the Elite. Quote Link to comment Share on other sites More sharing options...
