Na-t conversions
Chasz86
The spike in timing is controlled via the factory NA ECU. Removing the ACIS setup on the car will not remove the timing spike.
It will occur if you have the mechanical ACIS valve or not. If you are using something like an eManage to piggyback the stock ECU, you will need to pull timing out in the ~4500rpm areas to avoid this issue. You will not have to worry about this using TT ECU.
I can make a better recommendation though. The "NA-T Bible" thread is really old now, and whilst it has some good knowledge in there, there are a number of areas that I'd recommend not trying. One of which is setting your car up using a TT ECU. Yes it half works, but its more trouble that its worth, trust me, been there got the t-shirt, wouldn't do it again.
Rather than spending money on expensive used stock ECU's, then bolting on an emanages and ruining your stock wiring harness to bodge a TT ECU in there. Take £500 go buy yourself an ECUMaster classic & an adapter harness. Now you will have the freedom to do whatever you like on your setup and not constantly have to fight a stock ECU or wonder if its doing the right thing etc etc.
Plug it in and voila you have a full running standlaone with sensors for less than a grand. Didn't have that available to us when the "NA-T bible" was written.
Also if you aren't looking for mad power, then leave the dizzy in. If you need COP without re-engineering half your engine, leave the dizzy in and use it as your triggering system for ECU. K.I.S.S.
Well said perfect idea, when was reading thread did wonder to myself if not chasing big power why mess about with COP and GTE ecu and all the other extra hassle and cost.
Keep the dizzy, keep it simple and will make it far easier and better set up aswell
  • Replies 56
Posted Images
Thanks for the recommendations and info Paying the membership and been a member of the forum has paid for its self tenfold already
Decided to go full stand alone I had a look at them ECUs and and at the links and decided to not cut corners am letting the KTM go am selling her and buying the ecu
When replacing fuel injectors on the Na-t can you go too large for bhp or would they just run at a lower volume?
/QUOTE]
Depending on your choice of ECU, it may struggle to control huge injectors.
I run 650cc Siemens DEKA on an AEM V2 no issue. Previously ran them on a Emanage Ultimate too.
Sent from my iPhone using Tapatalk
