NA-TT BPU Dynapack
joehezzo
Engine Type - OEM TT
Engine Spec - Stock
Turbo - Stock
Fuel Used - 95
Exhaust - 3" Double Decat, 4" HKS High Power Silent
Transmission - R154
ECU - Stock
Mapped By -
Dyno Used - Underwoods Carlisle Dynapack
Power figure - 291 HP HUB (no correction)
Torque figure - 286 ft-lb
Boost Pressure - 0.8 BAR (restricted with reducer in mid pipe)
Only other Mods are 255 fuel pump, big pipercross Filter
  • 3 weeks later...
  • 4 months later...
Very happy with the result for something I normally run at 1bar, good to see it make what it should at stock levels, plans moving forward would be aiming for 500crank/450hub with rebuilt hybrids, standalone ecu, r35/tfsi COP, mild cams, uprated SMIC (probably my limiting factor) ans other tweaks
