Mike2JZ Posted April 25, 2020 Share Posted April 25, 2020 (edited) - Used 3'' Intercooler, good for around 600bhp. Got a little toasty around the 700bhp range, so changing for something else. Hopefully this can help someone out there looking for an entry level budget friendly intercooler setup. I used it for 2 years without any major issues. - Pipework is built for single turbo conversions using stock inlet manifold. - Pipework is powdercoated satin black & uses mikalor clamps. - Pre TB inlet pipe has 2 1/8 NPT bungs. I used one for IAT and another for Meth Injection nozzle. - Intercooler has mounting brackets so will bolt straight in. Turbo side pipes may need to be adjusted depending on placement of your single turbo & turbo outlet size. Price: £150 + Post or collect from SRD. Edited April 26, 2020 by Mike2JZ (see edit history) Link to comment Share on other sites More sharing options...
AC93 Posted April 25, 2020 Share Posted April 25, 2020 Is the pipework 3"? Link to comment Share on other sites More sharing options...
Danhook97 Posted April 26, 2020 Share Posted April 26, 2020 would this fit for na-t? Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 26, 2020 Author Share Posted April 26, 2020 would this fit for na-t? You could make it work, but you would have to change your inlet side pipework depending if you are still running na inlet or a ffim Is the pipework 3"? Mix of 70mm and 76mm iirc Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 26, 2020 Author Share Posted April 26, 2020 Sold now Link to comment Share on other sites More sharing options...
