New owner
Snakeysteve
heres the spec list
ENGINE SPEC​ –
3.0 2JZ GTE
FORGED ENGINE
MAHLE PISTONS
MANLEY RODS
TOYOTA BEARING SET
ARP HEADBOLTS
ARP MAINS
GW264 CAMS
UPRATED VALVE SPRINGS
HOLSEN 55 MODDED TURBO KIT
XS MANIFOLD MODDED
APEXI 3.5 SYSTEM MODDED
CUSTOM DP
LARGE UPRATED INTERCOOLER
UPRATED IC PIPEWORK
LARGE KN FILTER
OIL RELOCATION KIT
GREDDY CATCH CAN WITH BRAIDED HOSES
UPRATED 1300CC INJECTORS
AEROMOTIVE FUEL PRESSURE REG KIT
UPRATED FUEL PUMPS WALBRO 450 X2
TEFLON FUEL LINES
VAG COILPACKS
DRIVETRAIN AND SUSPENSION​ –
6 SPEED GETRAG V160
TILTON TWIN PLATE CLUTCH KIT
UPRATED MASTER AND SLAVE CYLINDER
TEIN SS COILOVER KIT
380MM KSPORT FRONT BRAKE SET UP
OEM REAR BRAKE SET UP
TRD LSD
Nice one! What cars have you come from?? Is this your first supra?
i started with a few RS fords then moved onto bmws, i had a 600bhp e36 turbo i built and also a e34 turbo.
i have a f80 m3 at the moment.
a supra has been a dream for years and decided to go ahead and buy one.
im starting to give up hope now
Have you tried dropping JDM distro a message? They maybe able to source you some.. or keep an on the Up garage/Croober site for them in japan. Will probably be your best bet in order to get them
Infect I think karmasupra on here has a set, maybe message Dave and ask where he got his set?
ive been looking on jdm distro just unsure of the best wheel specs to get so i can get the best tyre combination.
ill message him thanks
