Paul372 Posted April 17, 2020 Share Posted April 17, 2020 Hi, Im thinking about swapping over my jap spec clocks/Speedo for uk spec ones. My first question is, I take it that nothing is different and it’s a straight swap. The second thing will the mph read correctly or will I have to change anything so it reads correct thanks Quote Link to comment Share on other sites More sharing options...
Mike_Mac Posted April 18, 2020 Share Posted April 18, 2020 I did this on my J-Spec and put a UK speedo unit in there. It was a straight swap, removed the need for a speedo converter and the odometer started clocking up in miles too. So, remove speedo converter, if fitted and either note the odometer reading so you can keep track of the correct total, or get it converted to the correct miles total before installing the UK speedo (which is what I did). Quote Link to comment Share on other sites More sharing options...
Paul372 Posted April 19, 2020 Author Share Posted April 19, 2020 Nice one cheers, where is the speedo converter normally located, think mine reads up in miles but unsure as on the speedo they change the kph to mph with a sticker by the looks of it Quote Link to comment Share on other sites More sharing options...
