rg500 Posted April 17, 2020 Share Posted April 17, 2020 I am refurbing my split rims and wondered which is the best way to reseal them as I don’t want to have any leaks and have unreliable wheels on the car, Has anyone been successful in resealing the split rims. Thank Tony. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 17, 2020 Share Posted April 17, 2020 (edited) Pretty easy to do to be honest Once we had assembled my 3 piece Work Equips and torqued all the nuts & bolts up we popped each wheel on the tyre/wheel balancing machine. Then whilst rotating the wheel by hand slowly filled the area where the pieces meet with something like tiger seal, then rotated the wheel again by hand and using something like a cake spatula smooth over the sealer, i think we used the top edge of a plastic cup to start with as it smoothed out the sealer nicely. Leave to set before fitting the tyres Never had a problem with leaks I've arrowed the area we filled with sealer Edited April 17, 2020 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 17, 2020 Share Posted April 17, 2020 What are your split rims ? Quote Link to comment Share on other sites More sharing options...
rg500 Posted April 17, 2020 Author Share Posted April 17, 2020 They are auto strata Modena two 5 spoke light weight wheels which came with the car when it was imported from Japan in 2002 so they are quite old but look nice all polished up. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 17, 2020 Share Posted April 17, 2020 (edited) Are these a 2 piece where the centre piece bolts to one outer piece ? or 3 piece like mine ? Edited April 17, 2020 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
rg500 Posted April 17, 2020 Author Share Posted April 17, 2020 They are 3 piece split rims. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 17, 2020 Share Posted April 17, 2020 They are 3 piece split rims. So they have a similar section like mine and if so just do what i did, you dont need a wheel balancer but that just made it real easy to apply the sealer, you could fit the wheel to a front hub with it on full lock and use that to rotate the wheel on Quote Link to comment Share on other sites More sharing options...
Noz Posted April 17, 2020 Share Posted April 17, 2020 I've been advised by lots of peoples to use bathroom sealant. Due to being moisture repellent. Has been great so far. Not that its seen huge amount of rain Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 17, 2020 Share Posted April 17, 2020 (edited) We did my wheels in 2008 and i sold the car in 2013 with no issues during that time This is what Ibrar uses now, Starcher PU sealer http://www.movacshop.com/product/wbox-pu-sealer-821/ Edited April 17, 2020 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
rg500 Posted April 17, 2020 Author Share Posted April 17, 2020 That looks like good stuff will probably go for that, another question where did you get your split rim bolts From or did you just reuse your old ones. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 17, 2020 Share Posted April 17, 2020 That looks like good stuff will probably go for that, another question where did you get your split rim bolts From or did you just reuse your old ones. I splashed out and replaced them all inc the nuts, got mine from this place http://www.titanium-touch.de/felgenschrauben_uk.html Give Ibrar a call at Speedwells he might be able to supply them Quote Link to comment Share on other sites More sharing options...
