Danhook97 Posted April 14, 2020 Share Posted April 14, 2020 Is there a difference between na auto box and the tt auto box? Link to comment Share on other sites More sharing options...
Style Posted April 14, 2020 Share Posted April 14, 2020 Yes Link to comment Share on other sites More sharing options...
ben_harmer32 Posted April 14, 2020 Share Posted April 14, 2020 I did quick search, found some conflicting information: One said the internals are pretty much the same but the TT has an electronic valve body and more clutch packs. The other said everything in the TT box was bigger and beefier. But either way the TT auto is a better box. Link to comment Share on other sites More sharing options...
Danhook97 Posted April 14, 2020 Author Share Posted April 14, 2020 I did quick search, found some conflicting information: One said the internals are pretty much the same but the TT has an electronic valve body and more clutch packs. The other said everything in the TT box was bigger and beefier. But either way the TT auto is a better box. Awesome! Thankyou ben! Link to comment Share on other sites More sharing options...
Annabella Posted April 14, 2020 Share Posted April 14, 2020 Everything you need is here. http://www.mkivsupra.net/vbb/group.php?groupid=57 Link to comment Share on other sites More sharing options...
Swampy442 Posted April 14, 2020 Share Posted April 14, 2020 The biggest difference is the TT box has line pressure controlled by the ECU, while the NA box does it manually via a cable, so you cant really fit either on the other Link to comment Share on other sites More sharing options...
evinX Posted April 14, 2020 Share Posted April 14, 2020 The biggest difference is the TT box has line pressure controlled by the ECU, while the NA box does it manually via a cable, so you cant really fit either on the other Think DavidP has done a TT box into his NA or maybe it was the valve bodies? Link to comment Share on other sites More sharing options...
Big Mark Posted April 14, 2020 Share Posted April 14, 2020 http://www.mkivsupra.net/vbb/group.php?groupid=57 The link above to the group will tell you all you need to know about the auto boxes. Link to comment Share on other sites More sharing options...
Danhook97 Posted April 15, 2020 Author Share Posted April 15, 2020 Thanks guys! Great help Link to comment Share on other sites More sharing options...
