herbiemercman Posted April 18, 2020 Author Share Posted April 18, 2020 Job completed today, took a couple of hours. Had to modify two spanners to access the rear turbo retaining studs, also the down pipe had to be removed.The failed gasket (see pic), had lasted a few weeks and you can see how the aluminium has burned away from the center outwards until it reached the last tiny bit, then it blew out. The replacement gasket is stainless steel laminates and has a swaged edge for extra strength, cost £6.50 from a top turbo supplier and refurbisher in Manchester. The big suprize for me was the improvement in performance and the much cleaner/sharper exhaust note. I realize that the MAP, (manifold absolute pressure), must have been compromised with the fairly large gas leakage and system pressure drop. Anyway all is well now with my bus and it is at it's best, perfect tick over, smooth cruising, and great acceleration, up to "silly" speeds. Herbie. 20200417_114422.jpg (956.1 KB) 20200417_114605.jpg (849.0 KB) 20200417_114441.jpg (553.2 KB) 20200417_122952.jpg (625.7 KB) Quote Link to comment Share on other sites More sharing options...
Mo Reviews Posted April 18, 2020 Share Posted April 18, 2020 Where's the rest of your turbo? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 18, 2020 Share Posted April 18, 2020 Wheres that trolley jack going?! Quote Link to comment Share on other sites More sharing options...
David P Posted April 18, 2020 Share Posted April 18, 2020 Wheres that trolley jack going?! I daren't mention it, he gets upset when folks suggest such things........... Quote Link to comment Share on other sites More sharing options...
tayr Posted April 18, 2020 Share Posted April 18, 2020 they're probably already flat so no biggy i guess Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 18, 2020 Share Posted April 18, 2020 Is that a piece of copper plumbing pipe used as an oil drain? Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted April 19, 2020 Author Share Posted April 19, 2020 Wheres that trolley jack going?! It is going onto a length of 4"x2" timber to spread the load along the floor pan. Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted April 19, 2020 Author Share Posted April 19, 2020 Where's the rest of your turbo? on the engine. Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted April 19, 2020 Author Share Posted April 19, 2020 (edited) I daren't mention it, he gets upset when folks suggest such things........... Hello David, Noz told me not to take what you say personally and your a nice cuddle bunny. I have told Swampy where my mechanic put the trolley jack,and why, he also used two axle stands. Edited April 19, 2020 by herbiemercman (see edit history) Quote Link to comment Share on other sites More sharing options...
herbiemercman Posted April 19, 2020 Author Share Posted April 19, 2020 Is that a piece of copper plumbing pipe used as an oil drain? /QUOTE] No not copper pipe Dr J would never go to that expence. It is 12mm Bundy and came with the turbo. Quote Link to comment Share on other sites More sharing options...
