blackrzs Posted April 10, 2020 Share Posted April 10, 2020 I purchased hurst lock line + kit from Titan.. Since ours is RHD and master cylinder is on right and abs on left (not like LHD everything on one side). Do i need to lengthen one line from master to abs? Quote Link to comment Share on other sites More sharing options...
drift_bear Posted April 10, 2020 Share Posted April 10, 2020 Mine was just fitted by the master and used the feed/return lines there, had it mounted to the inner wing up by the bulk head Quote Link to comment Share on other sites More sharing options...
blackrzs Posted April 10, 2020 Author Share Posted April 10, 2020 And none with the abs?.. By any chance yiu a pic of it pls Quote Link to comment Share on other sites More sharing options...
blackrzs Posted April 10, 2020 Author Share Posted April 10, 2020 Mine was just fitted by the master and used the feed/return lines there, had it mounted to the inner wing up by the bulk headAnd none with the abs?.. By any chance yiu a pic of it pls Quote Link to comment Share on other sites More sharing options...
drift_bear Posted April 10, 2020 Share Posted April 10, 2020 I had an issue with mine, check out this thread (page 2 and 3) should help and give you a rough guide to fit http://www.mkivsupra.net/vbb/showthread.php?309254-Line-lock-problem/page2 Quote Link to comment Share on other sites More sharing options...
blackrzs Posted April 10, 2020 Author Share Posted April 10, 2020 I had an issue with mine, check out this thread (page 2 and 3) should help and give you a rough guide to fit http://www.mkivsupra.net/vbb/showthread.php?309254-Line-lock-problem/page210x [emoji120] Quote Link to comment Share on other sites More sharing options...
