ROAD COURSE - Which TURBO!?!? Goal 650whp
RZtwin
Injectors. 1100cc plus. One walbro 485 will do it but be on its limit. Fuel pressure regulator. Teflon fuel lines front to back. Billet fuel filter. Flex fuel sensor. Also a decent stand alone ecu to control it all.
A manual car will use less fuel to make the same power I did. As my set up has a lot of losses due to trans and torque converter.
  • Replies 53
I have recently purchased the Haltech 2500, guess I now need the complete radium Engineering mkiv supra fuel system..
I use a Borg 366sxe on my track supra, really happy with performance and reliability, not sure if your 272 cams are abit aggressive for your goal though.
Can you elaborate "aggressive " ? Doesn't the cam profile simply determine when the power is delivered within the powerband?
Yes exactly that, the 272s along with the turbo you require for your power goal will be coming on strong much higher in the rev range and to get full use of your power band you`ll need to be revving to atleast 8k which you can`t do on a stock bottom end, for circuit work you want a linear power as possible starting from say 3.5k upto 7.5k, this will give the motor more reliability as you`re not kicking its head in all of the time, all imo of course.
I wouldn't say cheap but Real Street Performance gave me a good deal on full Radium fuel system and ID1700X injectors.
Thanks Man, I have been talking to Russ over there at Real Street. The CAD dollar is crap today so hopefully by Black Friday it will have risen. Thanks!
That graph doesn't look right to me. That turbo shouldn't be running out of puff towards the end of the power band at under 800hp...
Hard to say without seeing the boost graph. But he's running that at 30psi (2bar).
Most precisions with mid size A/R's start dropping boost on the high end (7.5k+), especially when running into the 2 Bar and beyond region.
Would need to know what A/R the housing is, but his graph looks fairly normal to me.
Again just assuming, but due to stock bottom end they could be ramping the boost in more progressively to help save rods as well.
Here's a comparison between 6466 on two different stock bottom end 2J's.
Red Line = Stock Cams, TT6, 2 Bar Boost. FSR Streetfighter Turbo Kit, Shell VPower
Blue Line = 264 Cams, Auto, 2 Bar Boost, SRD Tubular manifold kit, Shell Vpower
Not an exact apple to apple comparison, but it's still fairly representative of the differences in spool from stock cams & log manifold versus top end power from cams & tubular manifold.
As Dan mentioned above, you will struggle on a 6466 to run 650whp whilst beating it around a track whilst using pump fuel. You would be at 1.7 Bar+ boost to make that kind of power, and things will get hot quick, especially on log manifold. If you have E85 readily available, then go for it. 6466 should be more than content to run 500-550whp with track abuse at a lower boost level on pump fuel however.
If you really want 650whp for track usage, then using a 6766 or 6870 will be better. Can run less boost for that amount of power on pump fuel, and the spool differences will be marginal.
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=235446&stc=1&d=1587491844
Thanks Mike2JZ. Awesome comparison!!
Is that blue line our dyno graph Mike?
Thanks for the clarification Mike.
Interesting to note the minimal effect the cams make on the torque...
Yup
I'd take it with a pinch of salt. The blue graph has progressive boost implemented due to stock bottom end, wheras red graph was asking for boost as hard and as soon as it could be mechanically delivered.
