Steering vibration issues.
Stock.supra.98
Update!!
So... I went to a tyre place (legitimate place!) And got the wheels off to check for a buckle... All 4 came back with zero buckle! I check the rears as well just to eliminate anything else! Got them all balanced, which was slightly out.
So back to square 1!
I've now put the tyres back on the original way, as the rears are wider.
I think I'll just have to buy new front alloys!
Update!!
/QUOTE]
Have a look for somewhere with a Hunter Road Force balancer. This will allow you to properly eliminate the wheel/tyre assembly being an issue.
If you swapped front to rear and it stopped. It would seem you relocated the issue so it will be somewhere there.
High or low spot in the wheel or tyre
Which is what I’d have guessed with the symptoms you’d said
