sidewaysdan Posted March 27, 2020 Share Posted March 27, 2020 Currently have these in Ngk r bcr8es they have work fine Just looking for some advice if these are the best for my setup . Upto 1.3 bar I’ve had a look at the thread regarding plugs Just wanted to know what you use Thanks dan Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 27, 2020 Share Posted March 27, 2020 They are fine, no need to bother going to 9's unless you are running 700hp+ Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted March 27, 2020 Author Share Posted March 27, 2020 700 I wish. So they need gapping to 0.07 Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 27, 2020 Share Posted March 27, 2020 700 I wish. So they need gapping to 0.07 Only bother gapping plugs if you are getting spark blow out during boost. If your spark is getting blown out then that points to weak ignition system, so if you are still running a dizzy then consider upgrading HT leads, or switch to coil conversion. Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted March 27, 2020 Author Share Posted March 27, 2020 Yeah still have the dizzy but have a set of 10mm leads . I’ll go coils when I upgrade my ecu Quote Link to comment Share on other sites More sharing options...
