jza800 Posted March 22, 2020 Share Posted March 22, 2020 After i have have all my brake lines apart and painting the abs block, i guess i need to bleed the Abs block.. i have bleed all 4 corners and got fluid out of all corners, when the engine is off the pedal is hard as i should, but if i start the car, after my opinion the brake pedal gets a little spongy, so i think i got air trapped in the Abs block. but how to i bleed the Abs block or how to i activate it without the special tool? the car brakes but again in my opinion the pedal is a little too spongy.. Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 22, 2020 Share Posted March 22, 2020 I used a pressure bleeder and with one corner cracked open turn on the ignition. And kept doing it until bled on all 4 corners. I think turning the ignition on primes/starts the abs pump for a second. I read this on the forum somewhere and it worked for me Link to comment Share on other sites More sharing options...
jza800 Posted March 22, 2020 Author Share Posted March 22, 2020 other that can confirm that? or can i bridge the relay in the relay box on the right side? Link to comment Share on other sites More sharing options...
jza800 Posted March 26, 2020 Author Share Posted March 26, 2020 No one that can help??? Link to comment Share on other sites More sharing options...
griffsplace Posted March 26, 2020 Share Posted March 26, 2020 mine just took forever, bleed and re bleed, and eventually a slug of crappy fluid through and that was it, brakes working perfectly. Link to comment Share on other sites More sharing options...
Dnk Posted March 26, 2020 Share Posted March 26, 2020 Isn't it covered in the repair manuals on the home page, top left Link to comment Share on other sites More sharing options...
jza800 Posted March 26, 2020 Author Share Posted March 26, 2020 But as my abs have been apart, there must be some air trapped in there, i the pedal get hard when the engine is of, but i think i drops to much when i start and it feels a little spongy so that's why i think there much some air trapped in the abs unit.. Only to need some tool, but i don't have that so maybe some in here have used another metode to get the abs pump to activate Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 26, 2020 Share Posted March 26, 2020 Have you tried what I mentioned above? It worked for me Link to comment Share on other sites More sharing options...
jza800 Posted March 27, 2020 Author Share Posted March 27, 2020 (edited) Yes i have bleed many times, and No dirt or bubbles comes out. So that make me belive that the last place aircan be traped is in the abs unit. It worked Greg before i tolk the car apart. But I dont have Any presssure bleeder, so it is done with 2 person, one in car and one at the wheel. Edited March 27, 2020 by jza800 (see edit history) Link to comment Share on other sites More sharing options...
rider Posted March 27, 2020 Share Posted March 27, 2020 Is the car on the level and are you bleeding with the pump live? Ignition on with light pedal pressure? Its better (easier) as a two man job. Link to comment Share on other sites More sharing options...
Big Mark Posted March 27, 2020 Share Posted March 27, 2020 How about driving the car and stamping on the brakes a several times so that the ABS activates and then bleed the brakes, that's what I've done in the past. Link to comment Share on other sites More sharing options...
jza800 Posted March 28, 2020 Author Share Posted March 28, 2020 Is the car on the level and are you bleeding with the pump live? Ignition on with light pedal pressure? Its better (easier) as a two man job. is i did that, but didn't hear the abs pump say anything. Link to comment Share on other sites More sharing options...
jza800 Posted March 28, 2020 Author Share Posted March 28, 2020 How about driving the car and stamping on the brakes a several times so that the ABS activates and then bleed the brakes, that's what I've done in the past. as the car is at storage due winter time , it would be nice if is was possible to activate it manual without driving it.. Link to comment Share on other sites More sharing options...
