Swampy442 Posted March 25, 2020 Share Posted March 25, 2020 I have a few Aristo auto ECUs, whilst not a permanent solution (your dash will light up like a Christmas tree) it will operate the engine and box fine Quote Link to comment Share on other sites More sharing options...
jza800 Posted March 25, 2020 Author Share Posted March 25, 2020 I have a few Aristo auto ECUs, whilst not a permanent solution (your dash will light up like a Christmas tree) it will operate the engine and box fine thanks for for offer, but cant use jdm ecus, it have to be a eu/uk spec ecu.. Quote Link to comment Share on other sites More sharing options...
Mika Posted March 25, 2020 Share Posted March 25, 2020 (edited) You will most likely going to need to have the General EU A/T ECU, Toyota part # 89661-14530 if your car is general Euro Spec Auto Supra. There might be some issues if using Austria / Switzerland A/T ECU, Toyota part # 89661-14550, as the Austria / Switzerland A/T ECU is programmed for different part # auto transmission and differential. But it also could work as it should. Theres also a possibility to use USDM A/T ECU Toyota part # 89661-14510 / 89661-14511 as the engine wire harness is same between US/EU Supras, but US Supra ECU`s does not have as good ignition timing and fuel charts as EU ones do. Also the differential and auto trans are different from the Euro Spec Supra. Edited March 25, 2020 by Mika (see edit history) Quote Link to comment Share on other sites More sharing options...
jza800 Posted March 26, 2020 Author Share Posted March 26, 2020 You will most likely going to need to have the General EU A/T ECU, Toyota part # 89661-14530 if your car is general Euro Spec Auto Supra. There might be some issues if using Austria / Switzerland A/T ECU, Toyota part # 89661-14550, as the Austria / Switzerland A/T ECU is programmed for different part # auto transmission and differential. But it also could work as it should. Theres also a possibility to use USDM A/T ECU Toyota part # 89661-14510 / 89661-14511 as the engine wire harness is same between US/EU Supras, but US Supra ECU`s does not have as good ignition timing and fuel charts as EU ones do. Also the differential and auto trans are different from the Euro Spec Supra. Thanks for the reply, have talked to toyota, and they say i need ecu with this number. 89661-14531, does that sounds right? Quote Link to comment Share on other sites More sharing options...
Mika Posted March 26, 2020 Share Posted March 26, 2020 Yes, 89661-14531 is compatible to 89661-14530. Quote Link to comment Share on other sites More sharing options...
blythmrk Posted March 26, 2020 Share Posted March 26, 2020 What is this one? https://www.ebay.com/itm/1993-1995-2JZGTE-Toyota-Supra-Turbo-auto-ECU-89661-14661-EU-spec-/263256417824 It’s the same part number as my U.K. auto ecu. Quote Link to comment Share on other sites More sharing options...
Mika Posted March 26, 2020 Share Posted March 26, 2020 What is this one? https://www.ebay.com/itm/1993-1995-2JZGTE-Toyota-Supra-Turbo-auto-ECU-89661-14661-EU-spec-/263256417824 It’s the same part number as my U.K. auto ecu. It is from the UK RHD A/T Supra: EUR, LB, RHD, 2JZGTE, ATM, 4FC Quote Link to comment Share on other sites More sharing options...
blythmrk Posted March 26, 2020 Share Posted March 26, 2020 It is from the UK RHD A/T Supra: EUR, LB, RHD, 2JZGTE, ATM, 4FC Ah ok I thought they would be the same or work in either! Quote Link to comment Share on other sites More sharing options...
