jonc Posted March 19, 2020 Share Posted March 19, 2020 I went to Mr T yesterday to pick up a new O2 sensor for my Sup as mine is fubared and they dont stock them anymore:blink: I'm after the VVTI version 89465-19725 but the only one I can find is on Aliexpress but they wont deliver to the UK (not sure if its because of the virus). Has anyone found someone who supplies these or an alternative? I thought if I was going to be in lock down i would get all the parts together so I can work on my cars in peace:innocent: I will dip mine in lemon juice overnight to see if it brings it back for the short term. Thanks in advance for anybodies guidance:clap: Link to comment Share on other sites More sharing options...
mellonman Posted March 19, 2020 Share Posted March 19, 2020 I got my pre vvti straight from denso after market . Link to comment Share on other sites More sharing options...
mellonman Posted March 19, 2020 Share Posted March 19, 2020 http://www.mkivsupra.net/vbb/showthread.php?262641-n-a-lambda-in-tt&highlight=Lambda This might help I put the links in my thread Link to comment Share on other sites More sharing options...
P_Bazz Posted March 19, 2020 Share Posted March 19, 2020 Being VVTi it should be a 4 wire heated sensor M18x1,5, if I remember correctly you can use either a Camry sensor 89465-06230 or a universal Denso sensor DOX-0109 (needs to be wired in to your old plug). Check the plug on the Camry sensor on Google pictures against yours but I think it's the same one. Link to comment Share on other sites More sharing options...
jongilly Posted March 19, 2020 Share Posted March 19, 2020 Have you tried amayama ? Link to comment Share on other sites More sharing options...
MartinB Posted March 19, 2020 Share Posted March 19, 2020 I replaced my sensor last year from Spark Plugs Ltd, Denso DOX-0228, it has the correct plug fitted, although the cable is slightly shorter it does reach. Link to comment Share on other sites More sharing options...
ben_harmer32 Posted March 19, 2020 Share Posted March 19, 2020 Opie oils sell them for a good price. Link in my thread below http://www.mkivsupra.net/vbb/showthread.php?354874-Using-to-much-fuel Link to comment Share on other sites More sharing options...
jonc Posted March 20, 2020 Author Share Posted March 20, 2020 Thanks everyone I didn't realise it was a well covered topic even though I did Google.. I can get pre VVTI from Denso or Opie but the VVTI unit is flanged on a 2 X bolt flange not a screw in. Apart from this are the O2 sensors compatible if I get a 4 wire as per above. I can re engineer the flange with a screw in fitting if needed. Cheers Jon Link to comment Share on other sites More sharing options...
ben_harmer32 Posted March 20, 2020 Share Posted March 20, 2020 The picture on the opie oils site is wrong. It comes with a 2 bolt flange. I'm not sure if vvti and non VVTI are the same though? Sorry I didn't read your first post properly. Just read o2 sensor lol Link to comment Share on other sites More sharing options...
ben_harmer32 Posted March 20, 2020 Share Posted March 20, 2020 This might help Link to comment Share on other sites More sharing options...
jonc Posted March 21, 2020 Author Share Posted March 21, 2020 This might help Thanks mate So according to this they are all the same? I think I will order one, fit it, test it and see what it does. It can't be any worse then the one on there Link to comment Share on other sites More sharing options...
jonc Posted July 17, 2020 Author Share Posted July 17, 2020 Just for closure the sensor that Opie fuels sell is a direct replacement for the VVTI single sensor so all good. Car is much happier now and not running rich. Thanks everyone for your help and guidance. Probably half the price of Mr T if they did stock them as well:D Link to comment Share on other sites More sharing options...
