Its all about the boost....
Fulcrum2000
Hi All
I am sure this is going to leave everyone laughing in the aisles at my expense, but I need the advice of more learned men than me in this field. My car is now full BPU with an HKS 6 running both turbos. On the screen it has the PH (highest boost achieved) setting and this reaches 28-30. The BC is set to not go above 17PSI which as we know is the safe limit for JDMs and the tuner says it is fine - so when the PSI max goes to 30 is that the combination of both turbos? Of course the turbos arent hitting 30PSi or they would be coming through the bonnet so I am guessing its saying both are 15? Just wanted to check all was ok before I finally enjoy my car and hopefully dont get the coronavirus!
Pressure is equal in a given area. With the turbos both running flat out it will be like two water pipes joining.
A max boost value means overall.
There is something not right with that. 30 psi is above what I've ever seen possible for stock turbos (unless it's back pressure spike from throttle run off or something).
Maybe its above atmospheric pressure so 14psi (1bar ish) + 16 (1.2bar ish) = 30psi?
It was horrendously hard to set up I can send a photo of the lines in the engine bay if you like but basically yes when I got it back it was set to 17.5 across all three parameters and it 33.3 and I thought that was too high so we set all to 17.0 and it now goes to 30. It feels as my previous car did now which was at BPU but it also has an AFR gauge in which is reading within parameters even with WOT. I dont pretend to understand it but I know if it was much above 1.2bar the turbos would not stand it and yes the HKS has an audible warning if the turbos over boost (it basically goes mental) so with that in place and no warnings how on earth can the HP be in early 30s? If it were short spikes I assume this is not harmful to the car and wouldnt I get some crazy AFR readings if it was overboosting?
