Na lsd
Frizzy
I would change at least the side bearings and seals while you change the unit to a new LSD, the pinion bearing would be fine as is not necessary to be removed. You will also need a set of new crown wheel bolts as these are not reusable as per Toyota instructions. I've swapped my NA5 to a TRD LSD a few years ago and these were the part numbers:
90301-96003 O-ring x2
90366-50033 Bearing x2
90311-47008 Seal x2
90105-12219 Bolt x10
90521-34003 Axle Stub snap ring x2
41336-24020 Dust cover x2
12157-10010 Case plug washer x2
If you do decide to do the entire diff you also need:
90368-34007 Bearing x1
41231-50010 Spacer x1
90311-44005 Seal x1
90179-26005 Nut x1
90201-700(XX) Adjusting Washer (numbers are 01-42 for a 1.87 to 2.28 mm adjustment)
  • 2 months later...
Just a quick one guys, a friend of mine might be breaking his facelift TT auto mk4, would the diff from that fit my 5 speed manual NA? and if so what differences will I expect over the open diff on mine already?
Thanks
