Syvecs S6 ECU
kwalker705
Do the Aristo and Supra use the same harness?
No different setups.. the harness plug was hardwired into the Aristo loom as no plug and play adapter was available for the aristo.
So youd need to source an adapter harness or repin the plug and hardwire it into your supra loom
About to swap out my syvecs S6 ECU for another unit. Will come with the harness connector.
Been used on my single manual aristo since 2014. Was purchased direct from Ryan G as part of a group buy on this forum.
Perfect working order. Currently still fitted to the car. ECU will be removed once a deposit it taken and then the rest of the payment taken once the ECU is ready to post out. Car can be seen running at the garage its located at in bicester. ECU can also be collected from there if it suits the buyer.
Looking for £1200 posted anywhere in mainland UK. Overseas shipping is available upon request.
What ECU are you replacing it with? Is the loom available from the Aristo? The reason I ask is that I have both a mk4 manual supra and an aristo i intend to build after the supra is finished.
If it helps the sale I have a brand new s6 harness for the supra was bought from Srd
How much are you after bud?
What ECU are you replacing it with? Is the loom available from the Aristo? The reason I ask is that I have both a mk4 manual supra and an aristo i intend to build after the supra is finished?
Afraid the aristo loom is staying with the car as it's still in use.
  • 2 months later...
