GE gasket replacement
sidewaysdan
Use OEM gaskets from toyota. I've seen & used cheap oem replacement gaskets that look like they do the job, but dont form a good enough seal so end up having to change them a lot sooner than usual.
When installing make sure you have a clean surface for the gasket to mate too. Usually cleaning with brake cleaner is enough. Avoid using RTV unless you have a damaged/warped mating surface / rocker cover that needs a bit of sillicone to help fill in the gap for better sealing.
If the washers for the rocker cover bolts are brittle & rock hard then maybe get a set of new ones. You don't want to over tighten the rocker bolts when installing the covers, and with hard washers its easier to over tighten.
I think the tightening torque is something silly like 6-8nm, but easier to tighten by hand. Using a small ratchet you can feel when the bolts are snug and dont want to tighten more.
When tightening start on the middle bolts and work your way outwards, tightening progressively. Usually takes 3 passes on the bolts like this to pull the rockers down evenly and compress the rubber gasket.
I've seen rockers sometimes leak after they have had fittings welded into them and they are slightly warped, so check on a straight edge if you have done something like that. But I think NA rockers are magnesium so shouldn't have same problem as GTE rockers.
  • 3 weeks later...
Looking good, don't over tighten them when putting it all back together. The common misconception is they need to be really tight or people keep just nipping them up and thats what destroys the Gaskets. Its really low at like 7 ft/lbs IIRC
