Battery connector
Dave
Do you mean the main negative cable? or other add on wires? It simply designed for you to clamp on to the right hand side of the picture, whatever is currently on your negative terminal?
Just as a word of caution, I have a voltage warning as part of my turbo timer, and was getting the odd alarm at junctions and traced this back to this not being fully tight (I either didn't tighten it sufficiently or it can vibrate loose over time with all these potholes etc)
I meant what’s the best way to secure the battery earth lead to this ,ie solder, nut and bolt ? how have you done yours ?
It’s just got a hole on the end as you can see in the pic
Done it now scooter thanks for the link for the connector
