How to perform a fuel pressure test on MKIV Supra
KaLiSupra
There is no where on the supra fuel system that will accept an off the shelf screw in fuel pressure tester.
Annoyingly most of the decent places to test the system from all use banjo fittings. You will need an banjo fuel pressure adapter such as: https://www.ebay.com/p/603113948
Easiest place to use this adapter will be on the fuel filter, you can use it on the rail but its tight.
  • 1 month later...
