wile e coyote Posted February 18, 2020 Share Posted February 18, 2020 (edited) Just a little write up on how I changed all the wheel bearings over the weekend. Now I only managed it due to having the use of a 4 post ramp , 30 ton press and plenty of tools in my mates garage. Tools needed Spanners, big hammer, grinder, 30ton press, various screwdrivers , wd40 or similar , sweat and blood So we started on the rears as there the worst to do. Sprayed all bolts nuts to help loosen Removed boot plastics and seats so as to disconnect the abs wire which is in the quarter panel be speaker. Push wire throght the floor and undo small bracket holding the wire, there also a plastic clip holding wire to top arm. Remove brake caliper. Remove rear disk and brake shoes. To remove the handbrake cable we had to just make the hole slightly longer as it fouls on the abs sensor. You could remove the abs sensor if your feeling brave ,due to these no longer available I didn't risk it and decided to remove the hub with it attached. Undo hub nut So now need to undo all the ball joints holding the hub on Then hit the joint with big hammer to shock them loose being carefull not to damage the boots. Remove hub We then hammered the centre of the bearing out with the flange . To remove the centre off the flange we grinded it down thin but to going right through then tapping it round with a hammer and slips off Press out old bearings and seals and press in new bearings taking care. Personally ide be giving the bearing etc to a machine shop to do unless you have the correct tools Then fit back on as a reverse of removal. The fronts were a lot easier. The abs plug is just behind the front wheel arch liner. I took advantage to replace the brake disc sheilds whilst off as you need to remove the bearing to replace. I did them as I had a very small bit of movement in one of the rears but this ended up being the best of them so very glad I did them before damaging the flange Few pics taken Hope this helps Edited February 18, 2020 by wile e coyote (see edit history) Quote Link to comment Share on other sites More sharing options...
Hammer Posted February 19, 2020 Share Posted February 19, 2020 Great write up cheers, I'm sure most of us need to get on and do this, I know I do so thanks for the info Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted February 19, 2020 Author Share Posted February 19, 2020 Your welcome Quote Link to comment Share on other sites More sharing options...
