Need a guaranteed value insurance.
Supra-love
I was with LWIB a few years back and always got a good deal, the owner was a fellow petrol head :)
Jason Livingstone was the boss at LWIB, i always spoke to him :)
Just checked and yes they merged a while back Nov 2013
Sky just quoted £860 with £550 excess and £100 excess for windscreen cover.
Ringing Adrian now!
Reis Motorsport gave me my best quote for single turbo. Unlimited modifications and agreed valuation.
Liked them so much got all my cars with them now as they also beat insurance prices not just for the Supra. Which also gives me 15% discount on the Sup next year. Winning!
Sounds good I’ll give them a call mate
What's the basic spec mate?
Full spec list below mate
Description-
Make: TOYOTA.
Model: SUPRA.
Milage: 52k miles.
Body: JZA80.
Colour: 040.
Engine: 2JZGTE.
Grade: RZ.
Drive: FR (front engine, rear drive)
Year: 1995.
Transmission: MTM.
Fuel: Unleaded 99 super.
Keys: 3 originals with pouch.
Alarm system-
Cat 1.
Clifford G5 concept 650 MKIII.
Proximity sensors.
2 cut immobiliser (ignition & starter)
Engine Management & Sensors:
Syvecs S6GP ECU.
Toucan Touchscreen Gauge.
Syvecs Map Sensor.
Syvecs S6 to 2JZ Loom Adapter.
Wideband Knock Sensor.
Wideband Lambda.
Boost Solenoid for Syvecs.
Oil Temperature for Syvecs.
Oil Pressure sensor for Syvecs.
Fuel pressure sensor for Syvecs.
Traction Cal switch for Syvecs.
Power cut off switch.
Mapping/Tune @RaceCal-
CAl switch with 12 positions.
A combination of different boost levels.
Launch on/ff.
TC on/off.
ALS on/off.
Ethanol map.
Road fuel map on varying cal positions.
700WHP approx.
Turbo setup-
New DBB PT6766 with uprated billet wheel.
New 4” intake K&N turbo filter.
Walton tubular manifold.
Twin comp 40mm wastegates & twin screamers.
HKS dump valve.
New 3” TB developments downpipe/mid pipe.
New 4” whifbitz cat back.
Fuelling-
New fuel injector clinic 1000cc injectors + pigtails.
New fuel injector -6an clinic rail kit.
New Teflon braided fuel lines -8an 2X -6an.
new -6an Bosch fuel filter.
New Aeromotive A1000 fpr + gauge.
New continental Flex fuel sensor.
Walbro 485 fuel pump.
Repainted ported Head -
New manifold nut & bolt kit.
New ARP 8740 head stud kit.
Ported exhaust side.
3 angle cut valves.
Full Re-shim.
New Bc Stage 2 264 camshafts.
New Bc springs and titanium retainers.
New Grade 8 spark plugs.
Super spark coil pack.
Repainted forged Block-
Balanced micro Polished oem crank.
New Balanced Manley H-tuff rods with arp 2000 bolts.
New Balanced Manley platinum turbo tuff pistons with extreme wrist pins. 86.5mm 9.0:1.
New King race mains/conrod and thrusts.
New Arp 8740 main stud kit.
(Millers cfs NT+ race 10w60 engine oil)
New Toyota full gasket and seals kit, from top to bottom.
Full gates vacuum hose replacement.
Ancillaries-
TRD oil filler cap.
New Trd thermostat.
Blitz radiator cap.
Koyorad radiator.
New silicone radiator hoses.
RED coolant.
SRD cooling plate.
Greedy intercooler.
New TB developments 3” intercooler pipes.
SRD Oil and power steering mocal coolers.
New Toyota oil pump.
New Toyota water pump.
New gates racing cam belt kit.
New Adjustable pulleys + high tensile bolts.
Clear cam cover.
New Billet tensioner.
Welded Toyota sprocket.
Toyota crank pulley.
New Toyota pulley tensioner.
New dayco pulley belt.
New gates vacuum pipes.
AC removed.
SRD battery-boot relocation.
New exide battery.
Transmission-
V160 Getrag 6 speed.
New Toyota V160 gear oil.
New Solid shifter bushes.
New Balanced Stage 3+ spec clutch kit.
New bearings.
Stock Toyota duel mass flywheel.
Differential-
TRD LSD in small auto casing.
Millers CRX LS 75W/140N
Suspension-
Nitron R1 race 1way coilovers + eibach springs - Fully serviced.
TRD sway bar sets.
Quick steering rack.
Rose jointed toe rods.
Brakes-
Millers 300+ Fluid.
UK spec callipers fully serviced.
Brembo brake discs.
Yellow stuff front & rear pads.
Goodrich braided lines.
Wheels-
New Toyota wheel bolts.
Toyota standard UK spec wheels refurbed.
Direnza 30mm front spacers.
Direnza 25mm rear spacers.
285/40/17 Bridgestone rear.
245/40/17 Bridgestone front.
Outer Body-
Original 040 super white.
Facelift rear lights.
Facelift front lights.
Underbody-
Complete restoration.
Full corrosion prevention.
Full raptor coatings.
New suspension Bushes.
Frames & arms powder coated.
Gearbox repainted.
New wheel bearings (rear)
Interior-
Standard full leather interior.
Black dyed floor carpets.
Kenwood DNX-7170 stereo.
2X Under seat nakamichi active subs.
Jl audio front and rear speakers.
Full Auto-mute sound deadening.
Built by SRD and Performance@Hart
Agreed value in current market for this spec £40,000?
Edited by Supra-love (see edit history)
Some basic spec that is lol.
Itll be the 700WHP and the mileage that's the biggest impact.
I knew they'd be the cheapest. Felt it in my bones!
Haha yeah basic mate..
Although she said it was engine size and bhp that affects it.
Didn’t ask the milage.
Modifications are unlimited otherwise.
For the value agreement she said 7 photos, full list of what the car has and some examples that are being sold that amount
