jongilly Posted February 16, 2020 Share Posted February 16, 2020 Need a tt rear subframe please Link to comment Share on other sites More sharing options...
rider Posted February 16, 2020 Share Posted February 16, 2020 Is the TT sub frame any different to a NA? Unless you want it with all the bushes, arms and sway bar fitted. Link to comment Share on other sites More sharing options...
bradleyh_15 Posted March 10, 2020 Share Posted March 10, 2020 I have one mate Link to comment Share on other sites More sharing options...
jongilly Posted March 10, 2020 Author Share Posted March 10, 2020 Sent you a pm Link to comment Share on other sites More sharing options...
Al Massey Posted March 14, 2020 Share Posted March 14, 2020 I have one too, will need sandblasted and painted Link to comment Share on other sites More sharing options...
rider Posted March 14, 2020 Share Posted March 14, 2020 I have one too, will need sandblasted and painted Oven baking and galvanizing is much better as blasting will never get inside the frame to remove all the rust that baking, acid dipping and galvanizing takes care off. Its not expensive either, £300 from memory. Link to comment Share on other sites More sharing options...
jongilly Posted March 14, 2020 Author Share Posted March 14, 2020 Sent you a pm cheers Link to comment Share on other sites More sharing options...
jongilly Posted March 14, 2020 Author Share Posted March 14, 2020 I believe there is no difference...between na an tt.. but i think i bought a soarer subframe which is similar, but different in no lower brace brackets and no exhuast hangers, and no mounting for hand brake cables, no holes for abs sensor brackets.. cheers Link to comment Share on other sites More sharing options...
Cam27 Posted March 15, 2020 Share Posted March 15, 2020 I believe there is no difference...between na an tt.. but i think i bought a soarer subframe which is similar, but different in no lower brace brackets and no exhuast hangers, and no mounting for hand brake cables, no holes for abs sensor brackets.. cheers Soarer rear subframe is completly different, tge lower arms are longer so different shape. Link to comment Share on other sites More sharing options...
