tt rear subframe wanted
jongilly
  • 4 weeks later...
I have one too, will need sandblasted and painted
Oven baking and galvanizing is much better as blasting will never get inside the frame to remove all the rust that baking, acid dipping and galvanizing takes care off. Its not expensive either, £300 from memory.
I believe there is no difference...between na an tt.. but i think i bought a soarer subframe which is similar, but different in no lower brace brackets and no exhuast hangers, and no mounting for hand brake cables, no holes for abs sensor brackets.. cheers
Soarer rear subframe is completly different, tge lower arms are longer so different shape.
