Uk spec brake rebuild
fastphil666
Hello everyone, my drivers front caliper has a habit of getting a bit sticky when not in use (all the time) im going to attempt to free it off but im pretty sure that will only be a temporary fix. Any good diy kits out there to rebuild them? Anyone done it with success? If all else fails, who do we pay to rebuild them?
Thanks
SRD is probably the first place I'd talk to about doing a refurb or exchange as they do offer this service and are reasonably priced. Having refurbed my own brakes and also bought refurbed calipers from SRD I'd say for the saving don't bother. Its a faff that'll end up in sore fingers stretching the dust boot over the pistons and probably the odd ripped dust boot along the way when you fit the retaining clip. Unless every penny really counts, get SRD to sort it for you.
I've stripped and re built them.
They're not hard to do but time consuming. Just freeing it off is waste of time
and needs fixing properly, the pistons could be re usable, really depends what you find
once you pop them out the calipers.
My recommendation would be take both the fronts off the car and get them done by one of the companies
offering this service. Unless your confident of doing the job yourself.
If you split them like i've done you'll need new seals that fit between the two halves and
Toyota don't sell them, CW on here used too, that's who i got mine off. You dont need to go
this far too be honest.
If you don't split them don't get them media blasted !
Do they do them in house ?
About 450 for the front and rears, rebuilt with new pots, seals, brake fixing kit, bleed nipples etc..... colour of your choice and or supra logos, or what ever you want... tell him Gilly sent you... cheers
If thats with new decent quality parts then its not bad, some kits inc pistons are very cheap though so
i'd have to know whats being fitted
  • 2 weeks later...
Good evening folks, i have a caliper off and apart ready to fit new seals etc to tomorow. Just a quick one, anyone know the torque spec for the 4 caliper bolts, that hold the 2 halves together? Tia
The recommendation is that you don't split the calipers on the 4 or more pots as the hudraulic fluid flows between the two halves and by splitting you could end up introducing leaks. The join has to be capable of withstanding 800psi hydraulic oil pressure. The torque spec on caliper bolts though is typically 55-60lbft. Watch that you don't lose the sealing rings if you aren't replacing those with new ones.
If you wet the seals before fitting and drop one half on top of the other, then hand tighten a couple of bolts and you should be OK I've split calipers because it does make servicing a lot easier and they have been fine when rejoined, just needs some extra care in re-assembly.
  • 2 weeks later...
