Supra-love Posted January 31, 2020 Share Posted January 31, 2020 (edited) The Motomachi supra project thread. Got a little bit more to do before I start a project thread, few more parts on way from at Tim @TBdevelopments. Want it to be a nice thread with plenty of pictures and details etc, so that’s to come over the next month or so when I get pictures. Edited September 15, 2021 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted April 23, 2020 Author Share Posted April 23, 2020 (edited) So finally I can reveal the full (very detailed) complete spec of my supra. Took a long time and lots of discussions with numerous people, but here it is for all to see. Still got a few parts (TBC) because of covid19 slowing things down. Please enjoy the read! Manufactured in the Motomachi plant (A22) in March 1995. Imported to the United Kingdom January 2008. 1 of 551, 040 white Supra’s built in 1995 Japan. Description- Body: JZA80. Colour: 040 super white. Chassis: RZ, Fully rebuilt at 53,436k miles. Engine: 2JZGTE, Fully built at 53,436k miles. Drive: FR (front engine, rear drive) Year: 1995. Transmission: MTM V160. Fuel: Unleaded 99ron super/E85 Alarm system- Category 1 - Clifford G5 concept 650 MKIII. Proximity sensor, Tilt sensor, Window sensor. B4.1 - 2 cut immobiliser (ignition & starter) Category S7-ATS MetaTrak tracker with 24/7 call centre support. Engine Management & Sensors: Syvecs S6GP ECU - Current firmware. Syvecs S6-2JZ Loom Adapter. Syvecs Toucan Touchscreen display. Syvecs Map Sensor. Syvecs Wideband Knock Sensor. Syvecs Wideband Lambda. Syvecs Boost Solenoid. Syvecs Oil Temperature sensor. Syvecs Oil Pressure sensor. Syvecs 10bar Fuel pressure sensor. Syvecs Traction Cal switch. Power cut off switch. Mapping/Tune- (TBC) Tuned and mapped by romain levesque @RaceCal. CAl switch with 12 positions. A combination of different boost levels. Launch on/ff. TC on/off. ALS on/off. Ethanol map. Fuel map on varying cal positions. Turbo setup- Oil and water cooled single scroll DBB PT6766, fully rebuilt with uprated billet wheel and new exhaust turbine. Funk motorsport carbon turbo jacket. 4” intake Funk motorsport turbo filter. Walton motorsport T4 single scroll tubular manifold. Gen V 60mm external wastegate and screamer pipe. HKS ssqv dump valve. 4” Custom aerospace downpipe. 4” Custom aerospace midpipe. 4” garage whifbitz single box cat back. Fuelling- New fuel injector clinic 1440cc high-z injectors with EV6 - Denso wire adapters. Fuel injector clinic -6an rail kit. Teflon braided fuel lines -8an 2X -6an. -8an Bosch fuel filter. Aeromotive A1000 fpr. e85 continental Flex fuel sensor. 2 stage Walbro twin 450 fuel pumps. Fuel pump retainer and clamp. Repainted ported Head - Toyota gaskets and seal replacements. Manifold nut & bolt kit. ARP 8740 head stud kit. Ported exhaust side. 3 angle cut valves. Shim gapped. Bc Stage 2 - 264 camshafts. Bc spring & titanium retainer kit. Iridium Grade 8 spark plugs. New Toyota oem coil pack. New Toyota coil clips. New ventilation hoses. Repainted forged Block - Toyota gasket and seals replacement. Professional Honing and skim. Balanced micro Polished crankshaft. New Balanced Manley H-tuff 625+ conrods. New Balanced Manley turbo tuff extreme duty pistons + extreme wrist pins. 86.5mm 9.0:1. New King race pMax black main and conrod kit with thrusts. Arp 8740 main stud kit. Tomei 194009 Type-R baffled sump kit. Toyota oil level blanking plate. Magnetic sump plug. Cooling - TRD oil filler cap. Blitz radiator cap. New Trd thermostat. Koyorad radiator. New stock radiator hoses. RED Toyota coolant. SRD cooling plate. New garage Whifbitz 5” full intercooler kit. SRD Oil and power steering mocal coolers. New Toyota oil pump. New Toyota water pump. Ancillaries- New Fluidampr crank dampener New gates racing cam belt kit. Billet tensioner. Welded sprocket. BC cam gears with arp hardware. New Clear cam cover. Fluidampr I-6 steel balanced crank dampener. New Toyota pulley tensioner. New dayco pulley belt. New gates vacuum pipes. New Toyota 1.4kw starter motor. New Toyota alternator. AC removed. SRD 0-Awg battery relocation. Washer fluid boot relocation. New exide EA1000 battery with 0awg connections. Transmission- Freshly painted V160 Gearbox. New D21065 gear oil. New V160 tripod retainer. New shifter orings, bolts and collars. New Toyota shifter bushes top and bottom. New Balanced Stage 3+ spec clutch kit. New clutch throughout, input & release bearings. Stock Toyota duel mass flywheel. Differential- TRD limited slip diff in small auto casing. Millers CRX LS 75W/140N Suspension- Nitron R1 race 1way coilovers + eibach springs - Fully serviced. Carbing rear strut brace. Carbing front strut brace with master cylinder stopper. Refurbished TRD front and rear sway bar set. Quick movement steering rack. Rose jointed toe rod ends. New wheel bearings (rear) Brakes- Millers 300+ Fluid. UK spec callipers fully rebuilt + powder coated. Toyota UK brake discs. Chris Wilson front & rear pads. Goodrich braided lines. Carbing Master cylinder brake stopper. Wheels- Oem Toyota wheel bolts. Supra UK spec wheels freshly powder coated. Direnza 30mm front spacers. Direnza 25mm rear spacers. 285/40/17 Bridgestone rear. 245/40/17 Bridgestone front. Engine bay- -10an Radium exhaust/intake swivel banjos. -10an Whifbitz staged catch can. Gas dampener Bonnet strut kit. Visible wire relocation/tuck. New fasteners and bolts. Funk motorsport heat tape and sleeves. Exterior- Stock look. Tinted rear windows. New Toyota wind deflectors. Custom decals. Original 040 super white. Facelift bumper bar insert. New Facelift rear lights. New Facelift front lights. New Facelift front indicators. New Facelift side markers. Stock side pod kit with complete new fitting kit. Rear number plate garnishes. Greddy style front lip. New rear boot stoppers. Bare metal 040 respray (TBC) Underbody- Complete restoration. Full inspection. Full corrosion prevention. Full upol raptor coatings. Cavity wax injections. Undercarriage bolts zinc coated. New suspension Bushes. Subframes & arms powder coated. Srd aluminium under tray. Interior- Standard full black leather interior. New stock shifter knob. New ash tray and shifter surround. New handbrake lever and surround. New complete set of dash and hvac buttons/knobs. Upgraded TRD cluster panels. New rear securing seat clips. Black dyed floor carpets. Audio- Boosted radio aerial window transmitter. Kenwood DMX8019DABS 7” wireless apple/android car play with reversing camera. 2 shallow kicker boot subs, running Rockford fosgate R500X1D amp - 1 channel. Ground zero GZIC16X 6.5” front 2 way components. Ground zero GZIF65X 6.5” rear 2way coaxial, running Rockford fosgate R250X4 amp - 4 channel. Complete Auto-mute sound deadening. Cared for @ DCAutoMotiveAndTuning Engine Tuned and calibrated by Romain @Racecal Agreed value - 45k Sponsors - Mishimoto Instagram - @The_Motomachi_Supra Facebook - The Motomachi Supra Instagram - @The_Motomachi_Supra Facebook - The Motomachi Supra https://www.facebook.com/TheMotomachiSupra/ https://www.instagram.com/invites/contact/?i=jk2oipgo6rco&utm_content=fdxuojq Edited September 15, 2021 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Mo Reviews Posted April 23, 2020 Share Posted April 23, 2020 Sounds awesome, look forward to seeing some Supra porn! Link to comment Share on other sites More sharing options...
mwilkinson Posted April 23, 2020 Share Posted April 23, 2020 May I ask how the Getrag was powder coated? Was it stripped down, powder coated, and then rebuilt? Link to comment Share on other sites More sharing options...
Supra-love Posted April 23, 2020 Author Share Posted April 23, 2020 AdamAMG said: Sounds awesome, look forward to seeing some Supra porn! Thanks buddy. Think I’ve covered everything now. Just little touches after the (TBC) items are covered. Will get as many photos as possible on here. Link to comment Share on other sites More sharing options...
Supra-love Posted April 23, 2020 Author Share Posted April 23, 2020 (edited) mwilkinson said: May I ask how the Getrag was powder coated? Was it stripped down, powder coated, and then rebuilt? Yes buddy James said (Edit) the old coating was fully stripped back, external parts removed/covered then painted silver. “Not powder coat” Edited April 23, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) So it’s March 2017 and these are the first photos I got of the supra, thought I should start from the beginning. Alex the previous owner sent her on the trailer I booked, down to srd to have a mot test, and full check over. Srd did the vehicle checks and all passed, then a pre mot check was done, it needed a few bits, so they wired in a fog light, done a full geo setup, replaced a spilt vac hose, secured rear battery, changed engine oil and filter as I requested, and fixed the non working horn wire. It failed the mot, Rose track joints had play and abs light was on. So srd checked this and the abs light wasn’t plugged in so plugged that in and put new rose track joints on and she passed. Minor advisories were for jacking point damage, the usual bent jacking points, and a second advisory for a slightly binding brake calliper. Quick few pics a friend took on my journey home from srd. On my way home I noticed it was holding back and backfiring at 4K revs was a bit confused by that. Seems that after going through every possible scenario, including the Syvecs ecu, it was a faulty fuel pump so got a new walbro 450 in there and ran perfect. Gave her a good well deserved clean up after that. Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) Next thing I thought to do when home was bead blast the horrid black nt-03 alloys, refresh the brake fluids and change the diff oil + gearbox oil. Then give her another good polish. Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) After sorting the brake fluid changes brakes felt much better than they did, also bent back the jacking points worst spots. Then took her to silverstone for a few laps on April 2017. Only got a few short videos. Edited June 6, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) Next thing I did was clean all the inside before adding back the full interior, a stereo and speakers, bit of sound deadening along with some soft rewiring. Your probably notice the before and after pics. Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) Went in for a full underbody recon, amongst other bits and pieces. Edited September 15, 2021 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) Car was checked over had a new mot on the car just after she arrived and passed with flying colours. So I started buying parts for the build was undertaking, changed my mind on the parts/build a few time’s over the course of time but things had to be right and now we are set to build a nice supra! https://uploads.tapatalk-cdn.com/20200612/744ff7c530794a8b3317c9f824e06789.jpg https://uploads.tapatalk-cdn.com/20200612/861910c52f97e8017c74014b379386d7.jpg https://uploads.tapatalk-cdn.com/20200612/0820284d1dd983dee6b8037ae2014f4f.jpg https://uploads.tapatalk-cdn.com/20200612/5e8294f4fe4fd5363d42a2c8a944fe8d.jpg https://uploads.tapatalk-cdn.com/20200612/3d0680b62f83815d59584507270f4929.jpg https://uploads.tapatalk-cdn.com/20200612/2e67458395bcd229bdae756fd4ce979d.jpg Edited September 15, 2021 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) Stripped the engine ready for the build, manifold bolts had stripped so had to get a new set. The engine and internals were very good condition. Only being 50k miles you’d expect so anyway. Now stripping it all ready for machining and forged internals etc https://uploads.tapatalk-cdn.com/20200612/7f16117655ae49649b54890d4e4c068b.jpg https://uploads.tapatalk-cdn.com/20200612/27d192f937421076de6b6c9775340ead.jpg https://uploads.tapatalk-cdn.com/20200612/13f2415ccc27f33e48d6f8f99079e6d7.jpg https://uploads.tapatalk-cdn.com/20200612/0d45c1b9c3dcba89206858f382a472e8.jpg https://uploads.tapatalk-cdn.com/20200612/b3bc2838d45041c767c05696ee02b1c3.jpg https://uploads.tapatalk-cdn.com/20200612/8e0350b7db39bfccc9a641833fd36586.jpg https://uploads.tapatalk-cdn.com/20200612/22a5763415c44f53775b2fd8550adb39.jpg https://uploads.tapatalk-cdn.com/20200612/23a531e98d62853aa42bad0e68f9c0e6.jpg https://uploads.tapatalk-cdn.com/20200612/7041cafe7abc5514beedfaf7d2eb4048.jpg Edited September 15, 2021 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) The underneath of the supra prior to all the treatment was spot on, no corrosion at all, all cavity’s were checked etc, but it’s something I wanted done to protect into the future anyway, our uk weather and roads are shocking so it had to be done. As your see the underneath was perfect before and even better after! James removed all components, deep cleaned the underside, removed all surface dirt, grit/dust etc and any degraded under-seal. She was then dried out for 48hours, and moisture tested. Which is most important part to stop present moisture as any moisture left deems the future protection useless. Some pics! Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 5, 2020 Author Share Posted June 5, 2020 (edited) Got the oem wheels refurbed and they are looking fabulous. https://uploads.tapatalk-cdn.com/20200612/ef9d3f3cf93e74dc8416282855a93139.jpg https://uploads.tapatalk-cdn.com/20200612/ef1c888cc4cdd09de05b3af669893b81.jpg Edited June 13, 2021 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 8, 2020 Author Share Posted June 8, 2020 (edited) Refurbished the stock cam gears yesterday after my workplace heat treated them. Was going to go with adjustable but I feel safer with stock. Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 8, 2020 Author Share Posted June 8, 2020 (edited) TRD oil filter for after the run in has been done Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 8, 2020 Author Share Posted June 8, 2020 (edited) Fuel injector clinic fuel rail kit and 1000cc injectors Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 8, 2020 Author Share Posted June 8, 2020 (edited) Manley turbo tuff pistons, extreme wrist pins & h-tuff plus series rods Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 8, 2020 Author Share Posted June 8, 2020 (edited) Tomei sump baffle kit just arrived to James Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 8, 2020 Author Share Posted June 8, 2020 (edited) New gauges for the tacho Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 8, 2020 Author Share Posted June 8, 2020 (edited) Nitron race R1s freshly serviced Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
Supra-love Posted June 8, 2020 Author Share Posted June 8, 2020 (edited) 285/40/17 Tyres for the rear and 30mm front and 25mm rear spacers for the front and rear stock Uk wheels. Edited June 12, 2020 by Supra-love (see edit history) Link to comment Share on other sites More sharing options...
