Shane34 Posted January 27, 2020 Share Posted January 27, 2020 Hi guys Could someone help clarify these are ok. 8.5" front et42 18" 245tyres 9.5" rear et 55 18" 275 tyres I have et 38 9.5" fronts which I noticed catch the bolt on the wheel liner on the very odd occasion. Appreciate the help. Quote Link to comment Share on other sites More sharing options...
Spunkmeyer Posted January 27, 2020 Share Posted January 27, 2020 Rear is a bit on the mild side Quote Link to comment Share on other sites More sharing options...
Shane34 Posted January 27, 2020 Author Share Posted January 27, 2020 Yeah comparison to my 9.5 et 38 rear it goes in 17mm which seems a lot. Quote Link to comment Share on other sites More sharing options...
Spunkmeyer Posted January 27, 2020 Share Posted January 27, 2020 I mean OEM is ET50 9.5 Rear isn’t it? Quote Link to comment Share on other sites More sharing options...
Shane34 Posted January 27, 2020 Author Share Posted January 27, 2020 Not sure, I'm guessing this sits well inside the arches, enough to lower a nice amount, but it's looks like I'd need a spacer of at least 10mm to look half decent? Quote Link to comment Share on other sites More sharing options...
Spunkmeyer Posted January 27, 2020 Share Posted January 27, 2020 (edited) Are you trying to fit a set of wheels you absolutely have to have because they are the shizzle? Or looking for recommendations as to what fits? Not sure what you mean by “enough to lower a nice amount” Edited January 27, 2020 by Spunkmeyer (see edit history) Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 27, 2020 Share Posted January 27, 2020 They'll look more tucked in than a pre op trannies nob. You'll either need some hefty spacers, or find a better fitting set of wheels Quote Link to comment Share on other sites More sharing options...
Delboy52 Posted January 27, 2020 Share Posted January 27, 2020 They'll look more tucked in than a pre op trannies nob. Lol Standard: Front - Alloy 17 x 8j +50, Tyre 235 45 R17 Rear - Alloy 17 x 9.5j +50, Tyre 255 40 R17 Do you have rolled rear arches? You can get an 18” 9j +35 wheel under standard, 10j +35 or +25 if arches are rolled. These were my sizes when I had stock arches with the rears rolled. Front - Alloy 18 x 8j +35, Tyre 235 40 R18 Rear - Alloy 18 x 9.5j +35, Tyre 265 35 R18 +10mm spacer Excellent resource for fitments. Enter in the stock 17” values and go from there https://www.willtheyfit.com Quote Link to comment Share on other sites More sharing options...
erachter Posted January 27, 2020 Share Posted January 27, 2020 (edited) I am running on stock arches the following setup: 8.5j ET45 235/40/18 +20mm spacer on both sides 9.5j ET40 285/35/18 no spacers The front wheels are sticking a tiny bit, like 2-3mm, but no rubbing. Rears are completely flush with the arches. I would not recommend running anything wider since you will definitely touch the arches. For your setup(ET55) I would say 275 is a bit too much for the rear, 265 would be perfect.. Edited January 28, 2020 by erachter (see edit history) Quote Link to comment Share on other sites More sharing options...
Shane34 Posted January 28, 2020 Author Share Posted January 28, 2020 Cheers guys found a set off BBS LM in those fitment but it will require spacers which are definitely not ideal. Quote Link to comment Share on other sites More sharing options...
