Panfish Posted January 25, 2020 Share Posted January 25, 2020 I recently purchased a 94 Supra turbo with the 6 speed manual transmission. When I depress the clutch, its makes a grinding noise. My friends believe it just needs a throw out bearing. Since this vehicle has an after market clutch that is very aggressive, I was thinking about getting something not as aggressive for someone like me who won't be racing the car. Anyone have suggestions on what to get? Thanks a lot!! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 25, 2020 Share Posted January 25, 2020 Depends on power output, usage etc so whats your set up engine wise? Quote Link to comment Share on other sites More sharing options...
Panfish Posted January 26, 2020 Author Share Posted January 26, 2020 Currently it still stock besides a front mount inter cooler. Down the road I would plan on getting a large single turbo, but I still want to be able to drive it reliably, not a daily driver at all, I'll probably only put on 1000 miles a year or less. I would say ultimate goal would be around 600HP. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 30, 2020 Share Posted January 30, 2020 First you need to see if the clutch uses the stock dual mass flywheel, and is till a pull type clutch. Or if has been converted to a push type and all the (very dear) pul type stuff has gone missing. All this can be seen through the bellhousing on a ramp with the little side vent covers removed (4 off 12mm hex bolts) This info is needed to make a sensible decision where to go next, Quote Link to comment Share on other sites More sharing options...
