Noz Posted January 21, 2020 Share Posted January 21, 2020 I have some spare lenses left over from various projects. They will need work to be usable, but might be good for a headlight intake or spare project if someone needs a spare lenses and is prepared to just put some time in. £20 + postage. I'm unable to source others to make complete sets or willing to deline another one to match. 1. Passenger side PreFacelift. Badly scratched on outside. 2. Driver side Facelift. Semi-delined. Sanded externally also, burnt in the centre. Paper on from being wrapped wet, easily removed. 3. Passenger side Facelift. Someone drilled holes in lower section, for water no doubt. I planned to fill the holes and paint a black surround on the lense, I often do this to hide the insert edges. 4. Passenger side PreFacelift. Pretty decent to be fair, no damage, just some scratches. Could be worked out and be a decent lense. 5. Passenger side Delined. Burnt inside edge, but again I paint a black edge around the lenses quite often so easily hidden. Would need to be finished sanding to bring to glass finish. Majority of this process is complete for you, as removing material to make them even takes far longer than just bringing the surface finish upto glass finish. Link to comment Share on other sites More sharing options...
