Manual conversion
suprano
Coming out next week as I'm going 6speed so will take all the pictures then, my w58 gearbox with all the gear linkage, which is very smooth and good condition personally done a few oil changes myself, the flywheel which should be good,the manual prop,and slave cylinder, you will need a clutch, and pedals not sure if I've read before you can make lexus is200 pedals fit be easy to get if so, asking £1000 and I can put it on a pallet no problem :) cheers
Edited by SPG (see edit history)
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
