Foxx Posted January 20, 2020 Share Posted January 20, 2020 Hi all, After the following or suggestions where to get them please: Stock exhaust from 2nd cat back VVTI Airbox, inlets and maf bits (excluding the maf sensor, appreciate they are rare) VVTI 1st decat pipe Fog light conversion electronics (think i read heckler PCB is ok or others you may have to wire into stock j spec lights) Guide for fitting a heckler pcb (link i found on an old post is dead) Hopefully a couple of pics attached if it helps at all. Tried online for about 6m for the airbox bits, no joy but no surprise. Also tried tonight for the fog light and exhaust, same story. We are visiting Japan in a couple of weeks so any leads/contacts there would be great (perhaps just for the airbox ) Thanks in advance Link to comment Share on other sites More sharing options...
Mo Reviews Posted January 20, 2020 Share Posted January 20, 2020 You can still get the exhaust from Toyota, I would however suggest you contact Paul at TCB as he will likely be able to give you a better quote than your local dealership. Good luck with the airbox... they're as rare as hen's teeth and cost upward of £350 if you are so lucky to even find one! The rest shouldn't be too hard to source with a little effort and persistence... Link to comment Share on other sites More sharing options...
Foxx Posted May 4, 2020 Author Share Posted May 4, 2020 So got most bits sorted other than the airbox. Is it possible to modify a non vvti airbox for the maf sensor and is it the same other than this fitment wise does anyone know? Link to comment Share on other sites More sharing options...
Dan8 Posted May 4, 2020 Share Posted May 4, 2020 Hi sorry I can’t really see the pictures using my phone is the air box you wanting for a NA or TT bud Link to comment Share on other sites More sharing options...
Foxx Posted May 4, 2020 Author Share Posted May 4, 2020 Ideally tt vvti, or non vvti if easy enough to add a slot for the maf Link to comment Share on other sites More sharing options...
