Mo Reviews Posted January 18, 2020 Share Posted January 18, 2020 (edited) Looking for a few OEM parts: 1. Back box bracket/hanger and O rings 2. MAF Sensor gasket/rubber seal 3. Airbox lower cold air feed Edited March 1, 2020 by Mo Reviews Bits found (see edit history) Link to comment Share on other sites More sharing options...
Mo Reviews Posted January 26, 2020 Author Share Posted January 26, 2020 Bump Link to comment Share on other sites More sharing options...
drift_bear Posted January 26, 2020 Share Posted January 26, 2020 I may have the stock exhaust hanger and the O rings as I took them off for the whifbitz system...I’ll lock later in when at the unit Link to comment Share on other sites More sharing options...
Mo Reviews Posted January 26, 2020 Author Share Posted January 26, 2020 I may have the stock exhaust hanger and the O rings as I took them off for the whifbitz system...I’ll lock later in when at the unit Thanks bud, drop me a PM if you find it please... Link to comment Share on other sites More sharing options...
Mo Reviews Posted February 4, 2020 Author Share Posted February 4, 2020 Bump Link to comment Share on other sites More sharing options...
Frank Bullitt Posted February 4, 2020 Share Posted February 4, 2020 Airbox lower cold air feed, the one that sits underneath the headlight? If it is, it's the same for '93-'02. They were available new from Toyota (17752-46060) when I ordered one in '18. I should still have my old one in the garage loft which you are more than welcome to. It just needs the foam gasket renewing where it slots into the airbox. Link to comment Share on other sites More sharing options...
Mo Reviews Posted February 4, 2020 Author Share Posted February 4, 2020 Airbox lower cold air feed, the one that sits underneath the headlight? If it is, it's the same for '93-'02. They were available new from Toyota (17752-46060) when I ordered one in '18. I should still have my old one in the garage loft which you are more than welcome to. It just needs the foam gasket renewing where it slots into the airbox. That's right, I have one on order with Megazip from their Japanese warehouse but they're currently on back order apparently. If however, that falls through for whatever reason, I'll drop you a PM. Thanks Link to comment Share on other sites More sharing options...
