Water in passenger side footwell
Scooter
Ok firstly it's a 100% rain water but leaking quite a bit in this recent inclement weather.
Got a storm force cover to go on shortly and will dry it all first as carpet backing especially needs it!
What I'm wondering when it comes to fixing it is, are there any other possibilities for water ingress other than the obvious windscreen seal/joint?
The passenger seat is out, carpet back and it's coming from the front bulkhead down under the ecu's not the seat belt area or from the base of the door.
This is normally the window seal. It's hollow so the water can channel down there and leak out near the ECU end. That's the cheapest thing to replace anyway
- - - Updated - - -
