Time to say goodbye to the Supra.....
marc_p
Morning Guys,
So with a heavy heart and after owning this one for 10 years, I am having to get rid of my Supra:(, I have driven maybe 1500 miles since picking it up from SRD 3 years ago and I am wanting to start my own business and need to raise the startup capital, so the Supra, 944 and possibly Corvette as well are being sold. I am wondering what someone would take it off my hands for as it stands. As you know, I have invested a lot of money into this car(I think it's around £50k but don't want to add it up!!). For those that don't know, I bought the car off another forum member 10 years ago as a standard facelift aerotop alongside buying a facelift TT6 hardtop to be used as a donor car for a shell swap and as far as I'm aware, it's still the only Facelift Aerotop in Europe to have both a 2JZ-GTE engine and V160/161 gearbox, that being said, facelift Aero's are pretty rare to start with as they were a JDM car only and made in very small numbers.
As far as issues, the car has two, firstly, the paintwork is tired (although underneath it is immaculate!) It's an RSP car but prior to my ownership it had a blowover respray in a lighter colour and it really should be put back to RSP, second issue is that it never got round to having a cold start map done on it, so once left for over 24 hours, it needs a little persuasion to start, it always starts but can take a little turning over (on the plus side, it's always meant that the engine gets well oiled before firing up after sitting for a little while :D).
Spec is as so:
Engine
2JZ-GTE Engine
Super Spark Coilpacks
Unorthodox Racing Water Pump Pulley
Unorthodox Racing Fan Pulley
Unorthodox Racing Alternator Pulley
Garage Whifbitz Idler Pulley
Borg Warner S366 Turbo w/ polished housing
Whifbitz Twin Wastegate Manifold
2x Turbosmart 40mm Wastegates
4" Alloy intake pipe
Goodridge braided oil feed line
Billet aluminium oil drain flanges
3.5" Kakimoto Exhaust System with 4.5" exit
K&N Air Filter
K&N ICV Filter
K&N Oil Filter
Whifbitz 3.5" v-band downpipe
Carbon Fibre Fuse Box cover
TRD Oil Cap
Gates Racing Cambelt
Gates Racing Fanbelt
Garage Whifbitz Magnetic Sump Plug
Garage Whifbitz Billet cambelt tensioner bracket
Powerhouse Racing Modified Cam Covers
Powerhouse Racing Breather System
NGK Iridium BKR8EIX Spark Plugs
Fuelling
AEM 380Lph Fuel Pump
Bosch in-tank adapter
Sard 800cc Injectors
Aeromotive Fuel Pressure Regulator
Aeromotive FP Guage
Garage Whifbitz Fuel Pulsation Dampner removal hose
Garage Whifbitz FPR Fitting Kit
Management
Motec M600 ECU
HKS EVC-S Boost Controller
Apexi Turbo Timer
Launch Control available Through Motec
Traction Control available Through Motec
Anti-Lag available through Motec
Secondary Lamba O2 sensor programmed through Motec
Full Throttle Up-Shift Programmed through Motec
Motec Data Logging
AEM AFR Gauge
TT6 Loom from donor car
ABS and TC system from donor car
GM 3 Bar MAP sensor
MAC Boost Solenoid
Cooling
AFR Dualcore intercooler
Koyorad Radiator
APR Carbon Fibre Cooling Plate
3.5" Alloy intercooler piping
Whifbitz 72 celcius thermostat
Twin Electric Fans
Drivetrain
V161 6 Speed Getrag Gearbox
TRD Gearbox Mount
TRD Clutch Line
RPS Cyn-R-G Flywheel
RPS Stage 3 6-Puck Clutch
AP Engineering Shifter Bushes
A03B Limited Slip Differential
Hubs, driveshafts, etc taken from TT6 donor car
Manual gearbox tunnel taken from TT6 Donor Car
Chassis
Tein Flex Coilovers
Tein Electronic Damping Force Control
Super Pro Lower Control Arm Bushes, front and rear, inner and outer
Super Pro Upper Control Arm Bushes, front and rear inner and outer
Super Pro Anti Roll Bar Bushes front and rear
Super Pro Subframe Bushes front and rear
Super Pro Steering Rack Bushes
Super Pro Diff Bushes
Subframes taken from TT6 donor car
Ultra Racing transmission tunnel brace
Driftworks rear camber adjusters
Braking
UK Spec Calipers
Brembo Disks
Brembo Pads
Goodridge Braided brake lines
Interior
Gear stick and handbrake gaiters trimmed in black leather with blue stiching
Sony double din headunit
Boston Audio speakers in place of standard speakers
Dash and clocks taken from Facelift TT6 Donor car
Carbon Fibre centre console cover
New OEM Parts
Crank Pulley
Cambelt Tensioner
Water pump
Oil pump
Exhaust Gasket
Inlet gaskets
Fuel Filter
Current mileage of the car is around 77k miles and although it currently has no MOT, it will have one put on for a buyer.
Also note that this is a high power single, with adjoining mods, so with the RPS flywheel and clutch and a TRD mount, the gearbox is noisy, with the engine mods, the car is noisy, don't expect it to be quiet and refined :D
Happy to answer any questions and thanks for reading.
[ATTACH=CONFIG]205162[/ATTACH]
[ATTACH=CONFIG]205163[/ATTACH]
[ATTACH=CONFIG]205164[/ATTACH]
[ATTACH=CONFIG]205165[/ATTACH]
Price bud?
/QUOTE]
Love this car mate and sorry to hear you're selling up.
Can't see a price anywhere though.....!
Sent from my SM-G960F using Tapatalk
Hey guys as I mentioned, although probably not too clearly, it's more a post to see what I would get for it as it stands, I've been out of the scene for a little while and not had chance to monitor what stuff has actually been sold for.
Sorry to hear this mate but good luck with the new business venture . What’s your plans ?
Hope to see you soon and catch up ,maybe dB or sclub party
- - - Updated - - -
At least the sale is on your terms and for the right reasons mate, GLWS!
As for price, I'd have thought around the 30k mark with it being a well built car with plenty of rare aspects to it. The whole chassis base / VIN number etc. for the purists is what puts it up in the air really.
