Key fob sync for keyless entry binding
Stephen88
Has anyone see this keyfob before?
I have been trying to bind it to my car... it comes with some sycning instructions requiring me to key into the ignition and cycle through lock and unlock via the door a number of times...
I had no luck? Has anyone bought one of these and managed to get it working?
https://www.ebay.co.uk/itm/Toyota-Supra-Jza80-OEM-Keyless-Entry-Fob-Sz-Szr-Rzs-RZ-Gz-2jz-TRD-1jz/293369717111?hash=item444e32a177:g:ylAAAOSwbXpdogwf
If you own a JDM Supra forget trying to sync a replacement fob. The JDM central locking unit comes with two fobs and that is it, you can I believe still buy the under seat unit with two new fobs for a lot of money. At least you could 2 years ago when I checked but I was put off by the price seeing you can buy generic c/l units with fobs for a few £ off eBay. If you had a US and I believe also the Euro spec Supra then the c/l module is located behind the steering column and that unit does have a red button pairing prompt on the box for new fobs.
