Terminator Posted May 6, 2003 Share Posted May 6, 2003 What would be the safe maximum width of tyre to fit front and rear to stock 17” rims while maintain safe road handing characteristics? Front rim is 9” and rear is 9.5”. Any advice much appreciated. Quote Link to comment Share on other sites More sharing options...
AJI Posted May 6, 2003 Share Posted May 6, 2003 I think its 275 on 9.5" and 245 on 9" but someone else would have to back me up on that. Quote Link to comment Share on other sites More sharing options...
outatime Posted May 6, 2003 Share Posted May 6, 2003 Originally posted by AJI I think its 275 on 9.5" and 245 on 9" but someone else would have to back me up on that. There was a thread on this a while ago, i think 275 + 245's are the max... 'Widest safe tyres on stock 17's' Quote Link to comment Share on other sites More sharing options...
Terminator Posted May 6, 2003 Author Share Posted May 6, 2003 Many thanks confirmed by use of the search button too, oops:stupid: Should know better. I'll get my coat;) Quote Link to comment Share on other sites More sharing options...
JCresswell Posted May 6, 2003 Share Posted May 6, 2003 Try This, I had a probelm with what tires to fit to my car as the rims where a little small, have a look its under performance tires all the sizes and rims you could fit the tires to http://www.toyo.co.uk/index2.html Some detail below from web site:::::: Last part is range of rim size the tire fits, (Toyo Proxies) Hope its of use 195/55R14 82V 570 201 267 - 5.5 - 7.0 185/55R15 82V 586 193 270 900 5.0 - 6.5 195/55R15 85V 596 200 274 885 5.5 - 7.0 205/55R15 88V 608 212 279 868 5.5 - 7.5 205/55ZR16 91W 631 212 291 836 5.5 - 7.5 215/55ZR16 93W 647 227 297 816 6.0 - 7.5 225/55ZR16 96W 654 229 300 807 6.0 - 8.0 245/55ZR16 100W 676 248 308 781 7.0 - 8.5 195/50R15 82V 577 199 267 914 5.5 - 7.0 205/50R15 86 V 587 210 271 899 5.5 - 7.5 225/50R15 91V 608 229 279 868 6.0 - 8.0 185/50R16 81V 592 194 5.0 - 6.5 195/50R16 84V 602 201 5.5 - 7.0 205/50ZR16 87W 613 210 284 861 5.5 - 7.5 225/50ZR16 92W 631 232 291 836 6.0 - 8.0 235/50ZR16 95W 643 244 295 821 6.5 - 8.5 205/50ZR17 91W 639 213 297 826 5.5 - 7.5 215/50ZR17 91Y 647 223 300 816 6.0 - 7.5 235/50ZR18 97W 694 244 321 760 6.5 - 8.5 195/45R14 77V 533 196 247 990 6.0 - 7.5 195/45R15 78V 558 196 260 946 6.0 - 7.5 215/45R15 84V 578 214 267 913 7.0 - 8.0 195/45R16 80V 586 196 273 6.0 - 7.5 205/45ZR16 83W 589 208 274 896 6.5 - 7.5 225/45ZR16 89W 606 227 281 871 7.0 - 8.5 245/45ZR16 94W 629 249 290 839 7.5 - 9.0 215/45ZR17 87W 626 214 292 843 7.0 - 8.0 225/45ZR17 91W 637 227 296 828 7.0 - 8.5 235/45ZR17 94Y 645 240 299 818 7.5 - 9.0 245/45ZR17 95W 654 249 303 807 7.5 - 9.0 255/45ZR17 98Y 662 258 306 797 8.0 - 9.5 245/45ZR18 96W 679 249 315 777 7.5 - 9.0 255/45ZR18 99W 687 258 318 768 8.0 - 9.5 225/40R14 82V 537 229 249 983 7.5 - 9.0 215/40ZR16 86W 578 218 270 913 7.0 - 8.5 225/40ZR16 85W 585 215 273 902 7.5 - 9.0 205/40ZR17 84W 597 209 280 884 7.0 - 8.0 215/40ZR17 83W 607 218 284 869 7.0 - 8.5 235/40ZR17 90Y 621 241 290 850 8.0 - 9.5 245/40ZR17 91Y 629 247 293 839 8.0 - 9.5 255/40ZR17 94Y 636 263 296 830 8.5 - 10.0 265/40ZR17 96Y 644 273 299 819 9.0 - 10.5 225/40ZR18 88W 637 229 299 828 7.5 - 9.0 235/40ZR18 91Y 645 241 302 818 8.0 - 9.5 245/40ZR18 93Y 654 247 305 807 8.0 - 9.5 275/40ZR18 99Y 677 278 9.0 - 11.0 285/40ZR18 101Y 685 291 317 770 9.5 - 11.0 245/40ZR19 96Y 679 248 8.0 - 9.5 255/40ZR19 96Y 687 260 8.5 - 10.0 245/35ZR17 87W 605 245 283 872 8.0 - 9.5 215/35ZR18 84W 607 218 288 865 7.0 - 8.5 225/35ZR18 83W 619 231 292 852 7.5 - 9.0 245/35ZR18 88W 629 245 296 839 8.0 - 9.5 255/35ZR18 90W 636 258 298 830 8.5 - 10.0 265/35ZR18 93W 644 269 301 819 9.0 - 10.5 275/35ZR18 95Y 650 278 304 812 9.0 - 11.0 285/35ZR18 97Y 658 289 307 802 9.5 - 11.0 295/35ZR18 99Y 664 300 309 795 10.0 - 11.5 235/35ZR19 91Y 647 241 305 817 8.0 - 9.5 245/35ZR19 93Y 655 248 309 803 8.0 - 9.5 255/35ZR19 96Y 661 260 312 793 8.5 - 10.0 275/35ZR19 99Y 675 278 9.0 - 11.0 245/35ZR20 95Y 680 248 322 773 8.0 - 9.5 255/35ZR20 97Y 686 260 8.5 - 10.0 265/30ZR19 93Y 643 271 305 818 9.5 - 10.5 275/30ZR19 96Y 649 278 306 813 9.5 - 11.0 275/30ZR20 97Y 674 278 320 779 9.5 - 11.0 Quote Link to comment Share on other sites More sharing options...
Terminator Posted May 6, 2003 Author Share Posted May 6, 2003 Thanks, just checked out 275/40/17 against the 16" standard wheel which came on the car at import. The 275 is the best size to fit for speedo accuracy. At 60 mph indicated the car will be doing just over 60.04 Also checking out Tirerack the 9.5" rim and 275 combo is the best to bring out the design characteristcs for the tyre I can live with both of those. Quote Link to comment Share on other sites More sharing options...
Steve W Posted May 8, 2003 Share Posted May 8, 2003 Phil, you said 9" fronts ? ? I thought you said 'stock' 17's ? ? aren't they 8" fronts, same as normal ? ? FatS. Quote Link to comment Share on other sites More sharing options...
