Axle Stands and Pads / Blocks
Tyson
I am going to be putting the Supra on axle stands and wanted to know what the individual rating should be per stand if there is one or is it combined axle weight ? I’d like ones with decent ground clearance too as I want to do some clearing up underneath over the winter if anyone has any suggestions.
Also I want to know if any of these block / pads that are supposed to be able to sit on the sill actually work and don’t allow damage. If not what are the alternatives ?
Most axle stands are rated to circa 2t, so more than adequate. The supra only weighs 1.6t in its entirety, so pretty much any axle stands on the market should suffice.
You won't be able to use blocks on top of stands though, that's a recipe for disaster. I'm surprised no one's developed stands with round 'cups' on the top, for the grooved rubber blocks to sit in.
/QUOTE]
There are some like this if I understand you correctly just reading some reviews where the blocks have cracked or split and wondered if there were any that someone had used and recommended.
https://jza80.mkivsupra.net/imports/2019/12/83.jpg
Other than the diff where is the best place for long term axle stands ?
Where the lift pads are ie where the scissor jack points are for changing a wheel and on the box sections just inside them on your pic? I'm a fan of the scissor jacks, they require physical effort and take time but the slots are good for the sill sections and they are easily/smoothly adjustable. I often lift mine with a scissor each side at the front and a jack on the diff as it's easy to get started. When up high you can lower nicely into the stands (with some very firm foam padding ie it compresses but not fully) and also leave some weight on both, so extra safe and least chance of damaging any jacking point.
