Mike2JZ Posted December 19, 2019 Share Posted December 19, 2019 (edited) Have recently switched to a V161, so my R154 setup is up for sale. This conversion is plug and play kit for MKIV Supra. No modifying of any sort, just bolt it in and go like Toyota designed it to. Will work with any JZ engine. If you are an auto chassis then you will also require some pedals and a manual tunnel obviously. Parts Included: New late model tripod R154 from Soarer/Chaser 1998+ Xtreme Twin Plate Sprung Ceramic 200mm Clutch & Flywheel Kit. [KTY20531-2B] Rated to 900 ft.lbs torque Includes Flywheel, Twin Plate Clutch Parts, ARP Flywheel Bolts, Pull to Push conversion parts, Slave Cylinder, New Pilot Bearing, Clutch Release Bearing. [*]SRD Heavy Duty One-Piece Propshaft. Rated for over 800 ft.lbs torque. Custom built to work between R154 to A01B/A, A02B/A*, A03B/A* (* requires smaller diff flange) [*]SRD Billet Shift Knob & Chassis Shifter Boots [*]R154 Gearbox Rubber Mount & Gearbox to Chassis Brace [*]Speedo Sensor [*]Left & Right hand side clutch covers [*]Custom length stainless clutch line from Master to Slave cylinder. Will not split the above yet, interested in selling as full kit. Gearbox was purchased new from Toyota Japan via RHDJapan, late July 2019, installed in car on August 2019 and taken for a ~1500 mile eurotrip and some pulls on a dyno. Has done mainly motorway miles, never been on track or launched hard etc. Given that it's basically brand new still, it shifts like butter, no whines or funky noises. Have documents and receipts for when it was imported into the country. Clutch kit has seen around 10'000 miles(was used with a MKIII R154 previously).Pedal is light, and engagement is smooth too, but does require around 1000rpm to pull away. I used to daily drive with this clutch with no issues, you can slip it when required due to sprung design, not overly grabby. Has seen a few launches and burnouts over its life,but friction discs have plenty of life left. Gives the awesome twinplate clutch noise when engaged. I actually love this clutch kit, so much so I ordered an identical one for my V161 setup. This conversion is currently located at SRD Tuning, so ideally collection from there. Would need a pallet to post these items, so would need quoting separately if interested. Gearbox conversion can also be fitted at SRD if required. Price : £4300 Edited January 16, 2020 by Mike2JZ (see edit history) Link to comment Share on other sites More sharing options...
Mo Reviews Posted December 20, 2019 Share Posted December 20, 2019 Saw this at SRD yesterday, appeared to be in great condition and as advertised. Link to comment Share on other sites More sharing options...
sidewaysdan Posted December 20, 2019 Share Posted December 20, 2019 Why do you have to put this up just before Xmas would love this Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 3, 2020 Author Share Posted January 3, 2020 New year bump and price drop to £4300 Link to comment Share on other sites More sharing options...
WayneW Posted January 3, 2020 Share Posted January 3, 2020 Woow you gone V161 mate ? Great news this GLWS !! Link to comment Share on other sites More sharing options...
Mike2JZ Posted January 16, 2020 Author Share Posted January 16, 2020 Sold Link to comment Share on other sites More sharing options...
