Crash Bandicoot Posted December 12, 2019 Share Posted December 12, 2019 Hi all, I’m taking my engine out as part of a freshen up over winter, while it’s out, I’ve decided to go for an aftermarket inlet manifold, I’m not looking at one of the “bolt on” eBay jobbies for £200... through eBay, there is a few from Australia “wildcat industries” for around £600 and the “np boosted” ones form canada.... that’s more my budget region. Can’t really justify a plasmaman one for £1200+ I’m Currently running GTE hks t04z full single turbo kit Has anyone got any feedback on what one to go for? Link to comment Share on other sites More sharing options...
Frank Bullitt Posted December 12, 2019 Share Posted December 12, 2019 Why do you want one and could the money used in buying one be put to better use else where on the car? Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted December 12, 2019 Author Share Posted December 12, 2019 Mostly for the Aesthetics... I want it to look different and have as many pipes hidden as possible, I plan on tucking wires and doing a slight bay smooth. It want the intake side to be as much of a statement as the turbo side. Link to comment Share on other sites More sharing options...
Sheefa Posted December 12, 2019 Share Posted December 12, 2019 I have an SRD Greddy style one and its great. Looks the part and a bit more headroom for power. Link to comment Share on other sites More sharing options...
Mike2JZ Posted December 12, 2019 Share Posted December 12, 2019 The cheap £200 manifold have an acceptable plenum design/finish given they are copies of greddy and cost peanuts. Biggest problem with them is the awful throttle bodies they are supplied with. Massive issues with reliability, leaking air, TPS irratic readings, sticky throttles etc. Avoid like the plague and use a Q45 throttle body or similar instead. The NP boosted manifolds for ~£500 are actually pretty good. I had my doubts at first but have installed and tuned a few, and the throttle feels like stock & so far no issues with reliability or daily driving with them. Only 'issue' is that if you use the stock IACV and install it on the port they build into the plenum, then you will find clearance between IACV & the oil filter housing/cooler very tight. This can make getting your hands down there a nightmare. Otherwise, for the money there is no better "bang for buck" inlet manifold. After this prices skyrocket and you are paying for brand names Hypertune, Sleeper Design etc. I have no data to suggest which inlet flows the best, or the most evenly between cylinders. But most should be fine if you arent tuning your car to the limit. Whilst on the subject, this is an interesting video to watch regarding inlet plenum performance. Sometimes bigger dosen't mean better. But it looks cool so spend away. Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted December 13, 2019 Author Share Posted December 13, 2019 Mike, hats off to you, this is the exact feedback I was looking for. Good comparison video too. As I’m not on a built motor “yet” I won’t be revving too high, so basically I’m expecting to loose some low end torque in place of a better looking engine bay. I can live with that. I’m leaning towards the np boosted (although I’d most likely paint it to suit the aesthetics of the rest of my engine bay. Thanks again Link to comment Share on other sites More sharing options...
Mo Reviews Posted December 13, 2019 Share Posted December 13, 2019 The only problem with the Greddy inlets is the need to fit a custom washer fluid bottle as the standard one won't clear the pipes. Link to comment Share on other sites More sharing options...
Style Posted December 13, 2019 Share Posted December 13, 2019 Just as an extra brand that's a bit closer to home to consider, SSI in Ireland do an intake that looks quite nice whilst also being well priced. I think it's a little more expensive than £5-600 but comes with a fuel rail and can be bought through a UK vendor. So you'll save on any import taxes and clearance fees Link to comment Share on other sites More sharing options...
Jellybean Posted December 13, 2019 Share Posted December 13, 2019 Just as an extra brand that's a bit closer to home to consider, SSI in Ireland do an intake that looks quite nice whilst also being well priced. I think it's a little more expensive than £5-600 but comes with a fuel rail and can be bought through a UK vendor. So you'll save on any import taxes and clearance fees One of the guys on here had his car in with Greg in protuner , Greg was impressed with it ; no leaking from the throttle body butterfly , is common with the cheaper units Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted December 13, 2019 Author Share Posted December 13, 2019 I’ll have a look into the ssi intake too Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted December 13, 2019 Author Share Posted December 13, 2019 offhand, if I’m moving bits around in the bay, will I need the longer throttle cable option (found on future motorsports site for the ssi intake) or can I reroute the oem cable to fit ok? Link to comment Share on other sites More sharing options...
Jellybean Posted December 13, 2019 Share Posted December 13, 2019 offhand, if I’m moving bits around in the bay, will I need the longer throttle cable option (found on future motorsports site for the ssi intake) or can I reroute the oem cable to fit ok? You do need a longer cable , Celica St205 cable (781802D390) or what Bijal has , PHR do a cable too I cannot find the thread on here but it was a white Supra ; remember his first dyno session with greg, his front main seal went on the oil pump Link to comment Share on other sites More sharing options...
Style Posted December 13, 2019 Share Posted December 13, 2019 You do need a longer cable , Celica St205 cable (781802D390) or what Bijal has , PHR do a cable too I cannot find the thread on here but it was a white Supra ; remember his first dyno session with greg, his front main seal went on the oil pump Shawn's? http://www.mkivsupra.net/vbb/showthread.php?318991-Shawn-s-UK-3-4-V160-Single-Ridox-Widearch-with-Red-Leather-Interior-Project-)/page41 Crazy money for a throttle cable but does make the job easy. There's always the option of having a bash yourself Link to comment Share on other sites More sharing options...
Jellybean Posted December 13, 2019 Share Posted December 13, 2019 (edited) Shawn's? http://www.mkivsupra.net/vbb/showthread.php?318991-Shawn-s-UK-3-4-V160-Single-Ridox-Widearch-with-Red-Leather-Interior-Project-)/page41 Crazy money for a throttle cable but does make the job easy. There's always the option of having a bash yourself Nope , wasnt that car; nearly sure it was a 6266 or 6466 Celica cable I got from Toyota was 180 euro Edited December 13, 2019 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted December 13, 2019 Share Posted December 13, 2019 my bad , ebay throtle cable is gone Link to comment Share on other sites More sharing options...
