Help finding E.T Alloy to fit 305.35.18
GreekSupra
Hello guys,
Need some help here, never understood wheels.
Facts:
I have coilovers teins
I dont mind my car to sit higher
I dont want my arches rolled
I dont want spacers
I have UK big brakes
Need:
XXR 535 wheels
TOYO R888R
255-265/35-40/18 front
305/35/18 rear
Can you please let me know what offset and wheel size (9.5 front & 11 rear) I need to comply with all above?
Thank you guys
Edited by GreekSupra (see edit history)
Hello guys,
Facts:
I dont want spacers
Need:
XXR 535 wheels
TOYO R888R
305/35/18 rear
Thank you guys
I'm no expert but if you post on this thread over at SF, Radride (username) most certainly is:
https://www.supraforums.com/threads/wheel-tire-size-offset-thread-search-here.558091/page-148
A 305 tyre will fit nice on a 11.5J rim, with an offset of around ET50.
This is a similar setup to what we run, although we have a 315/30/18 tyre on a 11.5J rim and the tyre sits flush with the rim and rear arches. Although we have our rear arches rolled to accommodate the wheels and tyres and also allow abit of “squat” in the suspension.
This will help you understand the changes that happen when you alter wheel diameters, offsets, widths etc
https://www.willtheyfit.com/
Just put in known figures for what you have now then put in the new sizes and the system calculates the
changes
I've taken a screen shot of OE 17" rears compared to what your possibly looking at
You can see compared to the OE wheel & tyre set up its very close in its diameter and only 4.4 mm bigger in diameter, the wheel goes 19 mm further in towards the shock/spring and comes further out to the edge of the wheel arch by 19 mm
Thanks guys
So the main problem now is where to find 18’ wheel 11.5 with ET50 !!!
I believe only custom work here :(
This is the difference between the wheel Chris posted and the 11" version, you can see it sits 6.4mm further away from the outer wheel arch which could work and not need any body mods like rolling the arch
