Imperialrs Posted December 6, 2019 Share Posted December 6, 2019 Newbie Looking for some guidance. Anyone assist. Car is an Aristo 2JZ GTE Non VVTI I am doing an engine conversion into a non Toyota Car and i am on the last bits and a bit stuck so looking for some advice. In one of the pictures there is a pipe with blue bit on it coming from throttle body, does anyone know where it goes? I have plumbed in all water pipes i need and have one outlet on top of the radiator, i am assuming this goes to an expansion tank which is fine. The expansion tanks i have seen have a secondary outlet usually at the bottom where does that go? See pictures. Going after market management and looking at coil packs at the moment what power is a standard coil pack good for? I hear you can use audi r8 ones, do they pop straight in or do you need brackets for them to keep them in place, same for Yaris packs? The power steering steering pump does picture look right? Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 6, 2019 Share Posted December 6, 2019 Secondary outlet on the expansion tank goes to ground, so just a long tube down to the front bumper/under tray. Quote Link to comment Share on other sites More sharing options...
