Supra crash
evinX
Jesus how bad is this comment around legislation in Russia!!!
"While it might be illegal to import a whole car from Japan, somehow it’s still legal to cut a car in half, import each half as car parts, and weld them back together wherever they end up, in this case, Russia"
/QUOTE]
Pretty terrible. But if they are happy to use a prohibited chemical weapon (Novichok) on foreign soil, exposing innocent members of public to the deadly toxin, I highly doubt they are too worried about this.
Edited by Frank Bullitt (see edit history)
If done properly (chopping and joining at the manufacturers original seems), isn't a cut and shut supposed to be relatively safe? Stretch limos and cruise ships being two examples where this is carried out on a regular basis.
I dont think you can replace the strength of one single piece by welding two together.... and typically when it is done by a chop shop its done on the cheap and without a thought of the consequences. Those other cars/uses are not meant for high speed, mainly cruising.
That is the point I am trying to make. If done properly. Welding two pieces of a car together in your mates back yard with no in-depth knowledge or thought into the rebuilding process isn't what I was referring to.
If all the joints are panel to panel, using the same kind of repair that manufacturers would use, done by a professional bodyshop using a jig then what would be the problem? If a damaged car can be rebuilt from the B pillar backwards what is wrong with using what is essentially a repair section welded to manufacturers standards?
This is a genuine thought and I'm not trying to condone the cut and shut method mentioned in the first paragraph.
Sure, looking at the pic its not a question I would even care about asking as I'd never want to own anything cut n shut :)
One original piece would bend, as you see those wrapped around tree, clearly the welds are weaker points compared to a single forged piece of chassis.
